Author Topic: Avaya / TServer TSAPI  (Read 2000 times)
Offline PFCCWA
« on: July 21, 2014, 08:30:37 AM »
Does anyone know where the invocation ID is generated from in a Avaya AES / Genesys TServer TSAPI solution?
Is it generated by Genesys application or Avaya AES?
thanks.
Re: Avaya / TServer TSAPI
« Reply #1 on: July 21, 2014, 08:42:50 AM »
I think it is generated at Avaya level.
Offline PFCCWA
« Reply #2 on: July 21, 2014, 09:15:34 AM »
apologies, you are right.
I should have given the scenario - Genesys is sending duplicate invocation id after not receiving response from Avaya AES from initial request.  When no response is received it is generating eventhardwareerror, leaving agent is desynchronised state.  As a result tserver thinks agent is ready (last known state), when agent has already changed state within Avaya (through windows tsapi client).  There is no further request from genesys for agent state after eventhardwareerror.
We can clear invocation id through aes reboot but needs to be each time the problem occurs.
Is there a way to prevent Genesys from sending duplicate invocation id? and waits longer for response from aes?
thanks.
« Last Edit: July 21, 2014, 10:24:44 AM by PFCCWA »
