Author Topic: Mandatory Disposition codes for mail  (Read 3253 times)
Offline gzooby
  • Software Engineer at Telefax S.A.
« on: July 16, 2014, 03:20:33 PM »
Hi!
Question:
I have established some disposition codes for agents and that´s working fine. Now I have installed e-services so thay are starting to work with email too. Disposition codes are mandatory, but they where just created for voice interactions not for email. So when I want to mark done, to reply or do something with email interactions, a messagge telling me Disposition Codes are mandatory appears. How can i DISABLE mandaroty disposition codes for email, but still be Mandatory for voice interactions??
Thank u!
Re: Mandatory Disposition codes for mail
« Reply #1 on: July 16, 2014, 04:49:26 PM »
What agent application is used by the agents?
Offline gzooby
« Reply #2 on: July 16, 2014, 04:50:44 PM »
They are using GAD :)
« Reply #3 on: July 16, 2014, 05:11:34 PM »
It is possible to override disposition code behaviour from routing by attaching key with predefined name to the interaction. Please look at Genesys Desktop 7.6 Deployment Guide, [i]Configuring the Disposition Code / Overriding The Default Disposition Code Behavior of the Routing Strategy[/i] section for more details.
Offline gzooby
« Reply #4 on: July 16, 2014, 07:07:20 PM »
Thank you!
I follow what´s in the manual, however I´m having some trouble!
inside disposition-code section i specified:
is-mandatory=true
use-attached-data=true
routing-overwrite-key=dispositionCode
Then in my strategy I atached a kvp like these
key: dispositionCode.is-mandatory
value: 'false'
I tried putting false instead of 'false' or just putting nothing and i can´t get it, still y want to mark done interaction the messagge Diposition code is mandatory appears!
Offline pablocaamano
« Reply #5 on: July 17, 2014, 01:36:45 PM »
You have to restart GDesktop in order to changes apply.  ;)
Offline gzooby
« Reply #6 on: July 22, 2014, 12:31:00 PM »
Thanks Pablo, i restarted GAD and everything worked fine!  ;D
