" /> IWS Toaster very slow - Genesys CTI User Forum
Author Topic: IWS Toaster very slow  (Read 2794 times)
Offline sshrikant
« on: June 13, 2014, 10:36:59 PM »
Excuse me if this has been posted elsewhere. I searched but could not find any reference.
The problem -
Users are complaining that the Toaster window shows up after several rings (2 or more) on the desk phone.
Most users have this issue 30% to 50% of the time. As it happens intermittently, it is hard to catch.
The environment is very basic - Avaya + Genesys, Voice only other media are not implemented yet.
I have removed UCS, Interaction Server etc from connections, disabled Contact look-up.
Is there anything else that can influence Toaster performance?
Offline genesysguru
    • Genesys Guru Blog
Re: IWS Toaster very slow
« Reply #1 on: June 14, 2014, 02:55:05 PM »
Sounds like latency on EventRinging to IWS. Pull off the local IWS log file whilst timing the actual time of ringing on the physical phone.
Offline GMG
  • GCP CIV 8X
« Reply #2 on: June 19, 2014, 06:24:15 AM »
Hello Srikant,
Do you have done any customization with third party CRM.
Sometimes, when call lands on IWS, we call a API, which gets some data from CRM, if API is taking time then pop-up comes late.
Have you tried using Vanilla version IWS ??
If you are already using Vanilla version of IWS, then please check with Network Team (about latency).
GMG
CIV-8.X
