" /> GetNumber Stat Server formula use - Genesys CTI User Forum
Author Topic: GetNumber Stat Server formula use  (Read 2037 times)
Offline mduran22
« on: June 06, 2014, 03:49:25 PM »
Hi All,
I just discovered the answer to a question that I have had for years but never spent time to figure out and thought I would share. We have an attached KVP that is a counter for RONA and increments each time a call redirects after not being answered. So this number can be 0 to any number. I needed a filter to count how many calls entered the queue after RONA. In the past I wouuld just create a new KVP with a true false for RONA and add it to the strategy or create a filter to use the RONA counter that would capture all possible values. I have had tried the past to use PairExist("RONA","*") > 1 which gave a syntax error in stat server. Yesterday I created the filter GetNumber("RONA") >= 1 which worked perfectly to filter any call that had the value for this key of greater or equal to one (could have also used > 0 I suppose) for specific stats.
Mike
