" /> Create “duplicate” Routing points in CME for different switches: - Genesys CTI User Forum
Author Topic: Create “duplicate” Routing points in CME for different switches:  (Read 2761 times)
Offline kapusta1152
Hello All,
Can we create “duplicate” Routing  points in CME for  different switches:
Example:
Number        Type                                Switch
12345        Routing Point                      Chicago_Avaya
12345        Routing Point                      NY _Avaya
Re: Create “duplicate” Routing points in CME for different switches:
« Reply #1 on: June 03, 2014, 01:46:41 PM »
Yes, you can.
Offline kapusta1152
« Reply #2 on: June 03, 2014, 02:21:56 PM »
Thanks for your prompt answer.
Offline mduran22
« Reply #3 on: June 03, 2014, 04:25:52 PM »
Only the Alias have to be unique (per tenant I believe).
Offline Dionysis
« Reply #4 on: June 13, 2014, 12:56:17 AM »
[quote author=mduran22 link=topic=8369.msg36806#msg36806 date=1401812752]
Correct, numbers can be the same, but the Alias must be unique.
