Author Topic: LRM 8.1/8.5  (Read 14942 times)
Offline PFCCWA
LRM 8.1/8.5
« on: April 09, 2014, 03:17:54 PM »
is anyone using License reporting manager?
Is it useful for customers?
We are considering but want to determine and weigh the benefits against a potential requirement to upgrade everything.
thanks.
Offline Timur Karimov
Re: LRM 8.1/8.5
« Reply #1 on: April 18, 2014, 07:30:17 AM »
[quote author=PFCCWA link=topic=8298.msg36533#msg36533 date=1397056674]
Hi there!
thanks.
Hi there!
We try to offer LRM to our customer to solve the day-by-day license monitoring task. But in current version it's useless for real-time and operativ monitoring. At the same time, historical view have also some problem in use coz it's count only limited product list. So it's looks like a good idea but need some time to wait when Genesys is step away from FLEX.
WBR Timur
Offline msd86911
Re: LRM 8.1/8.5
« Reply #2 on: April 30, 2014, 04:13:31 PM »
It is mandatory if you are upgrading to Framework 8.5
LRM has to connect to confserv at least 1 time or else confserv won't accept any connections from clients.
Re: LRM 8.1/8.5
« Reply #3 on: April 30, 2014, 04:23:04 PM »
[quote author=msd86911 link=topic=8298.msg36614#msg36614 date=1398874411]
WTF? Seriously? Isn't that a coaction to buy a product?
Offline msd86911
Re: LRM 8.1/8.5
« Reply #4 on: April 30, 2014, 06:53:55 PM »
i think it will be bundled in Framework from now on.
The idea is to keep track of Genesys License in new ways, not just numbers (how many) but also functionality like GVP and Genesys Media Server.
Re: LRM 8.1/8.5
« Reply #5 on: May 29, 2014, 10:41:16 AM »
Did any one deploy framework of version 8.5? I have still encountered with issue above configuration server license...
Offline Gaia
Re: LRM 8.1/8.5
« Reply #6 on: September 17, 2014, 01:30:58 PM »
I installed configuration server 8.5 , i start it using script run.sh , i got error
Configuration Server will exit due to invalid license
I try to install LRM
Installing License Reporting Manager, version 8.5.000.06
Please enter the hostname or press enter for "myhost" =>
Please enter the following information about your Configuration Server:
Configuration Server Hostname =>config server host
Network port =>2020
User name =>default
Password =>
Client Side Port Configuration
Select the option below to use a Client Side Port. If you select this option,
the application can use Client Side Port number for initial connection to
Configuration Server.
Do you want to use Client Side Port option (y/n)?n
Invalid host (myhost) or port (2020) for Configuration Server connection.
How to install LRM if i cannot start config server  >:( >:( ??????????????
Re: LRM 8.1/8.5
« Reply #7 on: September 17, 2014, 01:59:43 PM »
By installing it properly?
What is yours servers name? Can you do a "host <name>" command?
Offline Janis
Re: LRM 8.1/8.5
« Reply #8 on: September 18, 2014, 06:39:08 AM »
You have to import license to config database now in version 8.5. Use command
confserv -license <path to license file>
Offline Gaia
Re: LRM 8.1/8.5
« Reply #9 on: September 18, 2014, 08:19:01 AM »
Thank you
I missed step  confserv -license <path to license file>
Offline Gaia
Re: LRM 8.1/8.5
« Reply #10 on: September 18, 2014, 08:21:22 AM »
hi all,
is it possible to install LRM whithout GAX ?
Offline Janis
Re: LRM 8.1/8.5
« Reply #11 on: September 18, 2014, 09:08:08 AM »
Yes, I installed it. Just to enable applications to connect to configuration server on startup. Not using LRM functionality itself.
Offline Gaia
Re: LRM 8.1/8.5
« Reply #12 on: September 24, 2014, 07:26:09 AM »
Hi janisk
which version did you installed ? 8.1 or 8.5
Offline Janis
Re: LRM 8.1/8.5
« Reply #13 on: September 24, 2014, 11:59:37 AM »
LRM 8.5.000.06
config server 8.5.000.16
Re: LRM 8.1/8.5
« Reply #14 on: October 20, 2014, 09:06:17 AM »
You have to start your confserv with argument "-license <path_to_the_license_file>" as first. It is described in deployment guide.
