" /> Using VAriables | Genesys Composer - Genesys CTI User Forum
Author Topic: Using VAriables | Genesys Composer  (Read 3065 times)
Offline sky_scrapper
« on: January 16, 2014, 07:43:43 AM »
Hi i am using one variable in one callflow..I need that variable to be used in another callflow.How to achieve this in composer.
Re: Using VAriables | Genesys Composer
« Reply #1 on: January 17, 2014, 01:34:36 PM »
After several workarounds i found this link..
  http://www.qfak.com/computers_internet/programming_design/?id=b475602#.UrFOr9IW3p8
Here,let me know whether it will work?and also we need a extra backend block to process it..Any straight approach is there to get a variable from one callflow to another?
« Reply #2 on: January 17, 2014, 02:12:42 PM »
As I wrote in your another topic, try to learn something about vxml applications - you can "push" data to another app via query string for example. So, the key-value pair will be in URI of requested vxml/xml.
