" /> Virtual hold Genesys Integration - Genesys CTI User Forum
Author Topic: Virtual hold Genesys Integration  (Read 5327 times)
Offline Ashok Nandha
« on: December 13, 2013, 01:52:53 PM »
Need help in configuring the Virtual hold strategy :). I have the VHT strategy which provided by VHT. I have installed and configured the VHT application. I need to configure with URS. I am new to VHT Deployment and IRD tool :(. It would be really helpful if any one provide any document.  :)
Offline Timur Karimov
Re: Virtual hold Genesys Integration
« Reply #1 on: December 16, 2013, 07:20:33 AM »
Hi Ashok
[quote author=Ashok Nandha link=topic=8133.msg35783#msg35783 date=1386942773]
VHT & Genesys integration is very complex topic: Do yo plan to use it with SIP or any over T-Server? With VXML NGI or native IVR? Do you plan to use multi-language promtp in IVR? Plan to use GVP for outbound call or try to make all based on URS? If can't answer on these questions by you self - I have the really strong suggestion to you - found some one near who undestud VHT deployment guide and make the test strategy for you
WBR Timur
Offline genesysguru
    • Genesys Guru Blog
« Reply #2 on: January 10, 2014, 03:27:29 PM »
Agreed. I would think very carefully about using VHT as the integration with Genesys is not that tight and you might not end up with the solution you were expecting ....
