" /> Create an interaction programatically PSDK 7.6 - Genesys CTI User Forum
Author Topic: Create an interaction programatically PSDK 7.6  (Read 3772 times)
Offline tamichan
« on: October 23, 2013, 12:15:08 PM »
Ok, I'm just not getting it.  Yes, I've read the help files.  I thought I had a solution using the Open Media server sample, but that just gets a record into the interactions table not the Interaction table.  Genesys support pointed me to the eServices documentation, but the dot are just not connecting.  If anyone can give a basic explanation on how to programmatically create an interaction to the Genesys newbie I would be most grateful.
Yes I'm a little frustrated.
Current code:
[code]
public void SubmitInteraction()
            string interactionServerName = "InteractionServer";//"<server name>";
            string interactionServerHost = "Host";//"<host>";
            int interactionServerport = 2020;
            string inboundQueue = "InboundQueue";
            string mediaType = "email";
            interactionServerConfiguration = new InteractionServerConfiguration("InteractionServer");
            interactionServerConfiguration.Uri = new Uri("tcp://"
            + interactionServerHost + ":"
            + interactionServerport);
            interactionServerConfiguration.ClientName = "InteractionServer";
            interactionServerConfiguration.ClientType = InteractionClient.MediaServer;
            InteractionServerProtocol interactionServerProtocol = new InteractionServerProtocol(new Endpoint(interactionServerName, interactionServerConfiguration.Uri));
            interactionServerProtocol.ClientName = "InteractionServer";
            interactionServerProtocol.ClientType = InteractionClient.MediaServer;
            KeyValueCollection userData = new KeyValueCollection();
            userData.Add("interaction:subject", "Incoming interaction");
            userData.Add("interaction:text", "Test Message");
            try
                interactionServerProtocol.Open();
                Genesyslab.Platform.OpenMedia.Protocols.InteractionServer.Requests.InteractionManagement.RequestSubmit requestSubmit =
                    Genesyslab.Platform.OpenMedia.Protocols.InteractionServer.Requests.InteractionManagement.RequestSubmit.Create(
                    inboundQueue,
                    mediaType,
                    "Inbound");
                requestSubmit.TenantId = 101;
                requestSubmit.InteractionSubtype = "InboundNew";
                requestSubmit.UserData = userData;
                IMessage response = interactionServerProtocol.Request(requestSubmit);
                interactionServerProtocol.Send(requestSubmit);
                string boo = response.Name;
                interactionServerProtocol.Close();
            catch (Exception ex)
                throw ex;
        }[/code]
Re: Create an interaction programatically PSDK 7.6
« Reply #1 on: October 23, 2013, 09:04:49 PM »
I am not at my PC now and cannot check my old-codes, but as I can see from your code, you did not create any object for interaction. In your code you did following:
1. Create configuration object for connection
2. Create protocol object
3. Create KeyValueCollection object with KVP (without interaction are unusable)
4. Open connection
5. ReqestSubmit - but what - interaction object is missing
I think, that the responce from IXN server must contain some error message..?
Offline tamichan
« Reply #2 on: November 05, 2013, 07:53:36 PM »
Sorry for the late reply.  I had to step back and take a deep breath.  Found a sample on the Genesys forum that I could walk through and see exactly what you are talking about.  I'm a newbie and needed detailed instructions.  Everything is working now and the pieces are falling into place.
Thanks!
