" /> PSDK 8.1/Java - monitoring stats for a large number of agents - Genesys CTI User Forum
Author Topic: PSDK 8.1/Java - monitoring stats for a large number of agents  (Read 3842 times)
Offline abudwill
« on: October 01, 2013, 05:36:14 AM »
I have been exploring using the PSDK (Java) to monitor certain agent stats and perform actions when a stat reaches a particular threshold for an agent.
I have built a proof of concept with StatServer using StatisticObject, StatisticMetric, Notification, and RequestOpenStatistic.  I have a MessageHandler that I have attached to my StatServerProtocol so that I can parse messages with stat updates that StatServer is sending me.
I am interested in doing this for a large number of agents (1000-1500).
Can anyone comment on if this will create too much traffic and work for StatServer?
Are there other more graceful approaches to monitoring stats for a large number of agents?
Regards,
Andrew
Re: PSDK 8.1/Java - monitoring stats for a large number of agents
« Reply #1 on: October 01, 2013, 05:46:34 AM »
Well yeah. Will create a load for SS as it has a limit of requests. So it is not about how many agents but how many stats you plan to do (stats x agent = full_load)
What I recommend if doing such deployment (will not discuss why) is to install a dedicated SS for such task.
Offline abudwill
« Reply #2 on: October 01, 2013, 05:53:54 PM »
Cavagnaro,
Thanks, this is good advice.
Regards,
Andrew
