Author Topic: Sequence of digits  (Read 3046 times)
Offline n3xth0p
Sequence of digits
« on: August 19, 2013, 04:18:19 PM »
Dear sirs.
How to assign a sequence of digits to variable or to parametr  "IGNORE_DIGITS" in CED?
I can't find example of syntax in documentation.
thanks in advance
Re: Sequence of digits
« Reply #1 on: August 19, 2013, 04:58:07 PM »
CED[] is the return of the Treatment CollectDigits. So after the object you just put a variable assigment, for example:
vDigits = CED[]
I don't understand however what you want to do with ignore digits parameter.
Offline n3xth0p
« Reply #2 on: August 27, 2013, 12:42:43 PM »
Sorry for my inaccuracy.
I mean, how to set a sequence of digits in the filed (look at screen).
for example, instead of asterisk '*' put digits 7, 8, 9.
I tryied put it separated by commas, but it is wrong.
[url=http://i59.fastpic.ru/big/2013/0827/78/1f602ee38766105048dc038b70d92c78.jpg]http://i59.fastpic.ru/big/2013/0827/78/1f602ee38766105048dc038b70d92c78.jpg[/url]
« Reply #3 on: August 27, 2013, 02:09:32 PM »
Well that will work or not depending on your PBX actually, not Genesys.
Read your TServer treatments section and see if supported.
Offline n3xth0p
« Reply #4 on: August 27, 2013, 02:50:27 PM »
thank you
