Author Topic: Composer speak date variable  (Read 3133 times)
anoredis
« on: July 03, 2013, 12:18:55 PM »
Hello there!
I am having a difficulty announcing the date that I store in a variable. My date has the following form: 2013-07-02
If I set it as a string the application announces it without a problem. But when setting it to Date inside the prompt block properties, the call is dropped when reaching it. I suspect it has something to do with the en-US.js file or the PromptSwitch.js.. Has anybody done something like this?
Thanks in advance!
Re: Composer speak date variable
« Reply #1 on: July 03, 2013, 02:27:45 PM »
  • Check your logs you will find the answer there
    Also understand how the JS file works and how to adjust it to your language if not in English
