Author Topic: SIP Server 8.1. Advice of Charge (AoC)  (Read 4753 times)
Offline genesysguru
    • Genesys Guru Blog
« on: January 15, 2012, 03:11:13 PM »
Anybody out there have any practical experience of using the SIP Server 8.1 AoC feature?
Offline GMG
  • GCP CIV 8X
Re: SIP Server 8.1. Advice of Charge (AoC)
« Reply #1 on: January 24, 2013, 05:07:52 PM »
Hello Man,
It is easy as I have seen documents.
Now we have ORS instead of URS (Urs dropped the session after routing it, and ORS keeps the session alive till the call is alive).
We have to bring ORS in picture, a scxml code check EventEstablished and send Tprivate request to SIP server, however when SIP receives TPrivate request, it generates SIP INFO to MG.
I have just started working on it. You need to have Scxml expertise to detect the events and generate the Tprivaterequest to sip.
Regards,
Gaurav
Offline kubikle
« Reply #2 on: January 24, 2013, 05:49:04 PM »
Or you can load IRD startegy on agent DN (it will start on EventEstablished), make it send private request about AOC and exit.
« Reply #3 on: January 25, 2013, 06:51:35 AM »
I do not think,that URS dropped a "session" after call routing. You can continue in strategy after routing to any endpoint. Unfortunately,I have not practical experience with AoC on Genesys SIP,so let me note,please,if somebody use it..I am just wondering :-)
Offline bublepaw
« Reply #4 on: January 25, 2013, 11:14:01 PM »
There are at least two customers who are in process o implementing this feature. Main issue is fact that Your SIP trunk provider must support it so it is mainly used by carriers.
Offline naviat
« Reply #5 on: October 07, 2014, 08:18:58 AM »
Sorry but anybody out there create an composer application with AoC? i used event queue.submit.done for transition to private service message (active charge), but when the calll landing to agent (agent don't pick up) then private service send already. How to fix this issue?
« Last Edit: October 07, 2014, 09:07:28 AM by naviat »
« Reply #6 on: October 07, 2014, 09:02:38 AM »
Just the fact, that the agent does not pickup incoming call is wrong :-)) Try to send AoC if the call is answered/established.
Offline naviat
« Reply #7 on: October 07, 2014, 09:19:08 AM »
So what's event for the call answered/established in composer? i just see queue.submmit.done  :-[
« Reply #8 on: October 07, 2014, 09:54:26 AM »
What about interaction.pick.done or interaction.accept.done?
Offline naviat
« Reply #9 on: October 07, 2014, 11:27:33 AM »
I was try with interaction.pick.done or interaction.accept.done, and the second private service don't sent anymore, just send with queue.submit.done event.
