" /> Inbound calls changes to internal on Hicom - Genesys CTI User Forum
Author Topic: Inbound calls changes to internal on Hicom  (Read 4413 times)
Gabriel Madoz
This happens with a Siemens Hicom 300e:
>1) We verified that when one extension from Siemens Hicom makes a call to a
>DNIS , everyting works FINE Genesys sees only one event and both ANI and
>DNIS are recognized
>2) But it seems that when an external C.O. call request same DNIS, instead
>of one event Genesys believes there are two independent events.
>For the first event genesys recognizes ANI and DNIS but in the "second
>event" no ANI and no DNIS are obtained, then system can not route the call.
>3) I summarize what we have been investigating until today with no results:
>3a) An Enginer that has experience with PABX Nortel suggested us to explore
>setting " origcallxferinit = orig " but no reults
>3b) Also explored command "Usedatafrom value original" this we are using
>to keep original DNIS original but does not affect problem reported
>3c) Also explored "Consultdatafrom "  default is "separate" other choices
>like "joint" and a thir possible value has been tsted with no change on the
>reported problem
Below I send the piece of Stat Server log for you to see what happens, first with an internal call (dialing 480, everything works ok) and then with an inbound call (dialing 480, the inbound call changes to internal, the connid changes, so for Genesys is another call so the attached data that comes to RP 40001 doesn't arrive)
[size=8pt][color=green] 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181620
'USER_REQ_ID' 0
'REQ_ID' 286
Server: [10/09/02 13:40:20] Switch 'Genesys_Switch', 'EventReleased'
ThisDN '3508'
ConnID 006500e9cab0c18a (28429976775737738)
Call Type 'Internal'
This Queue '40001'
DNIS '40001'
CustomerID 'Resources'
Action: Extension '3508@Genesys_Switch' State:
Monitored since [10/08/02 13:45:01]
LoggedIn since [10/08/02 13:47:08]
WaitForNextCall since [10/08/02 16:16:22]
OffHook since [10/09/02 13:40:20]
Server: [10/09/02 13:40:20] Switch 'Genesys_Switch', 'EventOnHook'
ThisDN '3508'
Action: ACDQueue '0002@Genesys_Switch' DNs Ready: 2
Action: ACDQueue '0002@Genesys_Switch' Agents Ready: 2
OnHook since [10/09/02 13:40:20]
ThisDN '3511'
ConnID 006500e9cab0c189 (28429976775737737)
Call Type 'Outbound'
DNIS '52800'
Action: Extension '3511@Genesys_Switch' State:
LoggedIn since [10/08/02 16:00:33]
WaitForNextCall since [10/08/02 16:00:38]
OffHook since [10/09/02 13:40:11]
ThisDN '3511'
Action: ACDQueue '0002@Genesys_Switch' DNs Ready: 3
Action: ACDQueue '0002@Genesys_Switch' Agents Ready: 3
Status:
  Agent '3511', 'WaitForNextCall', [10/09/02 13:40:20]
    Place 'Place_3511_Genesys_Switch', 'WaitForNextCall', [10/09/02 13:40:20]
      Extension '3511@Genesys_Switch', 'WaitForNextCall', [10/09/02 13:40:20]
Client: Sending message to 'UniversalRoutingServer' (472)
Client: [10/09/02 13:40:20] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'USER_REQ_ID' 0
'REQ_ID' 288
Status:
  Agent '3508', 'WaitForNextCall', [10/09/02 13:40:20]
    Place 'Place_3508_Genesys_Switch', 'WaitForNextCall', [10/09/02 13:40:20]
      Extension '3508@Genesys_Switch', 'WaitForNextCall', [10/09/02 13:40:20]
Client: [10/09/02 13:40:21] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181621
'USER_REQ_ID' 0
'REQ_ID' 286
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventOffHook'
ThisDN '3512'
Action: Extension '3512@Genesys_Switch' State:
LoggedIn since [10/08/02 15:00:31]
WaitForNextCall since [10/08/02 15:59:37]
OffHook since [10/09/02 13:43:00]
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventDialing'
ThisDN '3512'
ConnID 006500e9cab0c18b (28429976775737739)
DNIS '480'
CallDialing (ConnID 28429976775737739) since [10/09/02 13:43:00]
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventQueued'
ThisDN '480'
This Queue '480'
DNIS '480'
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventRouteRequest'
ThisDN '480'
This Queue '480'
DNIS '480'
Extensions
'AgentGroup' '16777217'
Action: RoutingPoint '480@Genesys_Switch' State:
WaitForNextCall since [10/08/02 13:45:01]
CallWait (ConnID 28429976775737739) since [10/09/02 13:43:00]
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventRouteUsed'
ThisDN '480'
This Queue '480'
DNIS '480'
ThirdPartyDN '2800'
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventDiverted'
ThisDN '480'
This Queue '480'
DNIS '480'
ThirdPartyDN '2801'
Server: [10/09/02 13:43:00] Switch 'Genesys_Switch', 'EventRinging'
ThisDN '2801'
This Queue '480'
DNIS '480'
Action: Extension '2801@Genesys_Switch' State:
NotMonitored since [10/08/02 13:44:48]
LoggedIn since [10/08/02 16:00:53]
WaitForNextCall since [10/08/02 16:00:54]
OnHook since [10/09/02 13:40:18]
CallRinging (ConnID 28429976775737739) since [10/09/02 13:43:00]
Status:
  Agent '3512', 'CallDialing', [10/09/02 13:43:00]
    Place 'Place_3512_Genesys_Switch', 'CallDialing', [10/09/02 13:43:00]
      Extension '3512@Genesys_Switch', 'CallDialing', [10/09/02 13:43:00]
Client: [10/09/02 13:43:01] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181781
'USER_REQ_ID' 0
'REQ_ID' 280
Server: [10/09/02 13:43:02] Switch 'Genesys_Switch', 'EventOffHook'
ThisDN '2801'
OffHook since [10/09/02 13:43:02]
Server: [10/09/02 13:43:02] Switch 'Genesys_Switch', 'EventEstablished'
ThisDN '2801'
This Queue '480'
DNIS '480'
CallInternal (ConnID 28429976775737739) since [10/09/02 13:43:02]
ThisDN '3512'
DNIS '480'
Status:
  Agent '3512', 'CallInternal', [10/09/02 13:43:02]
    Place 'Place_3512_Genesys_Switch', 'CallInternal', [10/09/02 13:43:02]
      Extension '3512@Genesys_Switch', 'CallInternal', [10/09/02 13:43:02]
Client: [10/09/02 13:43:03] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181783
'USER_REQ_ID' 0
'REQ_ID' 280
Server: [10/09/02 13:43:03] Switch 'Genesys_Switch', 'EventAttachedDataChanged'
ThisDN '3512'
DNIS '480'
ThirdPartyDN '2801'
User Data
'IvrOrigin' '002001A'
ThisDN '2801'
DNIS '480'
ThirdPartyDN '2801'
User Data
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventReleased'
ThisDN '2801'
This Queue '480'
DNIS '480'
Call State 'Transferred'
User Data
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventPartyChanged'
ThisDN '3512'
Previous ConnID 28429976775737739
DNIS '480'
ThirdPartyDN '2801'
User Data
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventQueued'
ThisDN '40001'
This Queue '40001'
DNIS '480'
User Data
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventRouteRequest'
ThisDN '40001'
This Queue '40001'
DNIS '480'
User Data
Extensions
'AgentGroup' '16777316'
Action: RoutingPoint '40001@Genesys_Switch' State:
CallWait (ConnID 28429976775737354) since [10/08/02 13:49:21]
CallWait (ConnID 28429976775737364) since [10/08/02 14:13:34]
CallWait (ConnID 28429976775737369) since [10/08/02 14:15:56]
CallWait (ConnID 28429976775737656) since [10/08/02 16:22:03]
CallWait (ConnID 28429976775737660) since [10/08/02 16:23:18]
CallWait (ConnID 28429976775737664) since [10/08/02 16:30:47]
CallWait (ConnID 28429976775737667) since [10/08/02 16:33:23]
CallWait (ConnID 28429976775737670) since [10/08/02 16:47:10]
CallWait (ConnID 28429976775737673) since [10/08/02 16:47:25]
CallWait (ConnID 28429976775737676) since [10/08/02 16:47:54]
CallWait (ConnID 28429976775737679) since [10/08/02 16:48:05]
CallWait (ConnID 28429976775737683) since [10/08/02 17:16:13]
CallWait (ConnID 28429976775737687) since [10/08/02 17:16:37]
CallWait (ConnID 28429976775737690) since [10/08/02 17:18:49]
CallWait (ConnID 28429976775737693) since [10/08/02 17:24:45]
CallWait (ConnID 28429976775737696) since [10/08/02 17:30:18]
CallWait (ConnID 28429976775737699) since [10/08/02 17:31:18]
CallWait (ConnID 28429976775737702) since [10/08/02 17:31:51]
CallWait (ConnID 28429976775737739) since [10/09/02 13:43:04]
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventRouteUsed'
ThisDN '40001'
This Queue '40001'
DNIS '480'
ThirdPartyDN '3508'
User Data
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventDiverted'
ThisDN '40001'
This Queue '40001'
DNIS '480'
ThirdPartyDN '3508'
User Data
Server: [10/09/02 13:43:04] Switch 'Genesys_Switch', 'EventRinging'
ThisDN '3508'
This Queue '40001'
DNIS '480'
User Data
Action: ACDQueue '0002@Genesys_Switch' DNs Ready: 1
Action: ACDQueue '0002@Genesys_Switch' Agents Ready: 1
CallRinging (ConnID 28429976775737739) since [10/09/02 13:43:04]
Status:
  Agent '3508', 'CallRinging', [10/09/02 13:43:04]
    Place 'Place_3508_Genesys_Switch', 'CallRinging', [10/09/02 13:43:04]
      Extension '3508@Genesys_Switch', 'CallRinging', [10/09/02 13:43:04]
Client: [10/09/02 13:43:05] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181785
'USER_REQ_ID' 0
'REQ_ID' 286
Server: [10/09/02 13:43:07] Switch 'Genesys_Switch', 'EventOnHook'
ThisDN '2801'
OnHook since [10/09/02 13:43:07]
Server: [10/09/02 13:43:09] Switch 'Genesys_Switch', 'EventOffHook'
ThisDN '3508'
OffHook since [10/09/02 13:43:09]
Server: [10/09/02 13:43:09] Switch 'Genesys_Switch', 'EventEstablished'
ThisDN '3508'
This Queue '40001'
DNIS '480'
User Data
CallInternal (ConnID 28429976775737739) since [10/09/02 13:43:09]
Status:
  Agent '3508', 'CallInternal', [10/09/02 13:43:09]
    Place 'Place_3508_Genesys_Switch', 'CallInternal', [10/09/02 13:43:09]
      Extension '3508@Genesys_Switch', 'CallInternal', [10/09/02 13:43:09]
Client: [10/09/02 13:43:10] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181790
'USER_REQ_ID' 0
'REQ_ID' 286
Server: [10/09/02 13:43:14] Switch 'Genesys_Switch', 'EventReleased'
ThisDN '3508'
This Queue '40001'
DNIS '480'
User Data
Server: [10/09/02 13:43:14] Switch 'Genesys_Switch', 'EventOnHook'
ThisDN '3508'
-------------------------------------------------------13:43:14]
ThisDN '3512'
DNIS '480'
User Data
ThisDN '3512'
OnHook since [10/09/02 13:43:14]
Status:
  Agent '3508', 'WaitForNextCall', [10/09/02 13:43:14]
    Place 'Place_3508_Genesys_Switch', 'WaitForNextCall', [10/09/02 13:43:14]
      Extension '3508@Genesys_Switch', 'WaitForNextCall', [10/09/02 13:43:14]
Client: [10/09/02 13:43:14] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181794
'USER_REQ_ID' 0
'REQ_ID' 286
Status:
  Agent '3512', 'WaitForNextCall', [10/09/02 13:43:14]
    Place 'Place_3512_Genesys_Switch', 'WaitForNextCall', [10/09/02 13:43:14]
      Extension '3512@Genesys_Switch', 'WaitForNextCall', [10/09/02 13:43:14]
Client: [10/09/02 13:43:15] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181795
'USER_REQ_ID' 0
'REQ_ID' 280
Server: [10/09/02 13:45:50] Switch 'Genesys_Switch', 'EventQueued'
ThisDN '480'
ConnID 006500e9cab0c18c (28429976775737740)
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
Server: [10/09/02 13:45:50] Switch 'Genesys_Switch', 'EventRouteRequest'
ThisDN '480'
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
Extensions
CallWait (ConnID 28429976775737740) since [10/09/02 13:45:50]
Server: [10/09/02 13:45:51] Switch 'Genesys_Switch', 'EventRouteUsed'
ThisDN '480'
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
ThirdPartyDN '2800'
Server: [10/09/02 13:45:51] Switch 'Genesys_Switch', 'EventDiverted'
ThisDN '480'
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
ThirdPartyDN '2801'
Server: [10/09/02 13:45:51] Switch 'Genesys_Switch', 'EventRinging'
ThisDN '2801'
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
CallRinging (ConnID 28429976775737740) since [10/09/02 13:45:51]
Server: [10/09/02 13:45:51] Switch 'Genesys_Switch', 'EventOffHook'
ThisDN '3512'
OffHook since [10/09/02 13:45:51]
Server: [10/09/02 13:45:51] Switch 'Genesys_Switch', 'EventDialing'
ThisDN '3512'
ConnID 006500e9cab0c18d (28429976775737741)
DNIS '5480'
CallDialing (ConnID 28429976775737741) since [10/09/02 13:45:51]
Server: [10/09/02 13:45:51] Switch 'Genesys_Switch', 'EventNetworkReached'
ThisDN '3512'
DNIS '5480'
Status:
  Agent '3512', 'CallDialing', [10/09/02 13:45:51]
    Place 'Place_3512_Genesys_Switch', 'CallDialing', [10/09/02 13:45:51]
      Extension '3512@Genesys_Switch', 'CallDialing', [10/09/02 13:45:51]
Client: [10/09/02 13:45:52] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181952
'USER_REQ_ID' 0
'REQ_ID' 280
Server: [10/09/02 13:45:52] Switch 'Genesys_Switch', 'EventOffHook'
ThisDN '2801'
OffHook since [10/09/02 13:45:52]
Server: [10/09/02 13:45:52] Switch 'Genesys_Switch', 'EventEstablished'
ThisDN '2801'
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
CallInbound (ConnID 28429976775737740) since [10/09/02 13:45:52]
ThisDN '3512'
DNIS '5480'
CallOutbound (ConnID 28429976775737741) since [10/09/02 13:45:52]
Status:
  Agent '3512', 'CallOutbound', [10/09/02 13:45:52]
    Place 'Place_3512_Genesys_Switch', 'CallOutbound', [10/09/02 13:45:52]
      Extension '3512@Genesys_Switch', 'CallOutbound', [10/09/02 13:45:52]
Client: [10/09/02 13:45:53] Message 'Info'
'LONG_VALUE' 0
'TM_LENGTH' 0
'TM_SERVER' 1034181953
'USER_REQ_ID' 0
'REQ_ID' 280
Server: [10/09/02 13:45:54] Switch 'Genesys_Switch', 'EventAttachedDataChanged'
ThisDN '2801'
Call Type 'Inbound'
DNIS '480'
ANI '3512'
ThirdPartyDN '2801'
User Data
Server: [10/09/02 13:45:55] Switch 'Genesys_Switch', 'EventReleased'
ThisDN '2801'
Call Type 'Inbound'
This Queue '480'
DNIS '480'
ANI '3512'
User Data
Server: [10/09/02 13:45:55] Switch 'Genesys_Switch', 'EventQueued'
ThisDN '40001'
Call Type 'Inbound'
This Queue '40001'
DNIS '480'
ANI '3512'
User Data
ThisDN '40001'
ConnID 006500e9cab0c18e (28429976775737742)
This Queue '40001'
DNIS '40001'
Server: [10/09/02 13:45:55] Switch 'Genesys_Switch', 'EventRouteRequest'
ThisDN '40001'
This Queue '40001'
DNIS '40001'
Extensions
CallWait (ConnID 28429976775737742) since [10/09/02 13:45:55]
Server: [10/09/02 13:45:57] Switch 'Genesys_Switch', 'EventOnHook'
ThisDN '2801'
OnHook since [10/09/02 13:45:57]
Server: [10/09/02 13:45:58] Switch 'Genesys_Switch', 'EventRouteUsed'
ThisDN '40001'
This Queue '40001'
DNIS '40001'
ThirdPartyDN '3508'
Server: [10/09/02 13:45:58] Switch 'Genesys_Switch', 'EventDiverted'
ThisDN '40001'
This Queue '40001'
DNIS '40001'
ThirdPartyDN '3508'
Server: [10/09/02 13:45:58] Switch 'Genesys_Switch', 'EventRinging'
ThisDN '3508'
This Queue '40001'
DNIS '40001'
[/color][/size]
Any help or suggestion would be greatly appreciated
« Last Edit: March 11, 2007, 11:02:09 AM by victor »
Marked as best answer by on October 16, 2025, 02:48:14 PM
PeterJ
Re: Inbound calls changes to internal on Hicom
« Reply #1 on: March 08, 2007, 02:35:14 PM »
  • Undo Best Answer
  • Hi Gabriel,
    could you describe the second (faulty) scenario in more detail (all objects on the switch call passes through)? Yeah, can analyse the log but  ::)
    Inbound call is coming from external network? Is some IVR involved?
    Regards,
    Peter
    « Reply #2 on: March 11, 2007, 11:12:49 AM »
    Gabriel,
    I looked at your log, but I cannot make heads or tails out of it.
    I have noticed ConnID 006500e9cab0c18c :
    [color=green][size=8pt]Server:  [10/09/02 13:45:50] Switch 'Genesys_Switch', 'EventQueued'
      ThisDN '480'
      Call Type 'Inbound'
      This Queue '480'
      DNIS '480'
      ANI '3512'
      ThisDN '480'
      Call Type 'Inbound'
      This Queue '480'
      DNIS '480'
      ANI '3512'
      Extensions
    [/size][/color]
    but I could not really see anything strange with it.
    Can you:
    1. write a step by step description of the test scenario (e.g. 1. outside dial 8213; 2. call reaches DN 8200; 3. URS route call to agent DN 1234) so we can actually see how call is behaving
    2. if possible can you post TServer log and not StatServer? TServer is responsible for handling attach-data, so if something is goofy, chances are it is there.
    3. What exactly is this "second event"??? Are you talking about EventQueued and EventRouteRequest? From the logs, both of them contain DNIS and ANI.
