PFCCWA -
If I'm reading your post correctly, I'm assuming that previously you did NOT have an IVR (callers went directly to a rep) and you recently implemented one.
There could be many reasons for the abandon rate going up, many of which are out of your control
- some people don't like change
- some people think that the IVR will take them more time to get done what they wanted to
- some people are too self-important to deal with a machine or to take time to learn how to navigate the system
- some people are too lazy
- some people don't like IVRs
Others are in your control
- Too many menu options on a single menu
(caller forgets what each option was before the menu finishes voicing)
- Menu or instructions not clear
(what is the user to do at a specific point?)
- Menu or informational blocks too long
- No easy way to reach an agent/help option changes from menu to menu
(on one menu, it's option 5, on another menu it's option 6, on another menu it's option 4, etc)
- Timeouts are too short
(assume the person has to read their account number from a piece of paper)
- Multiple digit entry inconsistent/Terminator inconsistent
(It asked for my 16 digit account number. Do I need to press the pound key afterwards? Or is it the star key?)
- data dips are too long/too much silence in between prompts
- Caller is "forced" to get through IVR before they can speak to a human
(no "rotary" or "I don't have my account" option)
- IVR sounds unprofessional
(amateur voice, too much background noise, uses too many different voices)
I agree with cav and ESS - you'll need to find out specifically WHERE they are leaving, which may lead you to WHY. Is it possible for someone internal to go through the IVR to provide feedback, who has not been involved in the project? Maybe one of the most non-technical people you can find?
