Author Topic: IVR with Tserver  (Read 3513 times)
Garland Parker
IVR with Tserver
I am having problems reading the UUI data that is added to our calls from our IVR I can see the data in the Tserver Logs, however I cannot retrive the code in VB. here is my sample code.
intListCount = EventInfo.UserData.GetCount
If intListCount > 0 Then
For intLoopCounter = 0 To intListCount 1
myKey = EventInfo.UserData.Get(intLoopCounter).Key
Select Case myKey
Case "UU_DATA"
Debug.Print "UU_DATA: " + EventInfo.UserData.Get(intLoopCounter).StringValue
End Select
Next intLoopCounter
End If
Can you point me in the right direction???
