" /> Interaction Workspace Integration - Genesys CTI User Forum
Author Topic: Interaction Workspace Integration  (Read 3442 times)
Offline Usha
« on: August 16, 2011, 11:04:19 AM »
Is it possible to integrate CRM applications with interaction workspace(IWS) and display screenpop along with data in interaction workspace(IWS)?
Offline jamesdockel
Re: Interaction Workspace Integration
« Reply #1 on: October 10, 2011, 06:19:31 AM »
It is depend on the capacity of your IWS. According to it you can integrate CRM applications.
