" /> Query to fetch call detail from infomart - Genesys CTI User Forum
Author Topic: Query to fetch call detail from infomart  (Read 2806 times)
Offline Learnmore
« on: July 04, 2011, 09:13:12 AM »
I am new to Infomart and I need to check the call result for a particular conn ID from Infomart. I basically want to figure out where the call was routed. Can you please help me which tables i need to refer to get this detail?
Thanks.
Offline Learnmore
I am able to fetch the Query manual and getting the stats counts.
Am getting few calls with TECHNICAL_RESULT_CODE = DIVERTED and RESULT_REASON_CODE=UNSPECIFIED :( What does it mean?
