Author Topic: Setting Up Email Alerts from CCPulse  (Read 2498 times)
Offline TLizotte
« on: June 22, 2011, 03:03:21 PM »
We have two office that use the same Statserver for CCPulse.  Sending an email alert from the southern office works fine. When I try to send something from the northern office CCPulse hangs and doesn't go anywhere.  Is there a setting/connection in either MS Outlook or CCPulse that we should be looking at?
Both offices have the same version of Outlook.  Any guidance would be appreciated.  Thanks.
Adam G
Re: Setting Up Email Alerts from CCPulse
« Reply #1 on: June 23, 2011, 09:16:18 AM »
Any chance you can post the code you are using...?
TT
