" /> ResourceManager Cluster Port - Genesys CTI User Forum
Author Topic: ResourceManager Cluster Port  (Read 3648 times)
Offline TheSailer
« on: June 15, 2011, 08:45:40 AM »
Hi guys,
I have a simple question, on deploymentguide:
member.1
Member 1
Describes the Host/IP and TCP port on which the member ID 1 can be reached. The format is IP:Port or Host:Port where Host/IP and Port specifies where this RM node can be reached for cluster communication.
Default value
(blank)
which port??
Offline fnunezsa
Re: ResourceManager Cluster Port
« Reply #1 on: June 15, 2011, 05:17:32 PM »
Really???
I'll answer your question, but first let me ask you something: do you have any idea of what you're doing???
[color=red][size=12pt]Describes the Host/IP and TCP port on which the member ID 1 can be reached[/size][/color]
You're configuring an RM cluster, right? So you have at least 2 RM, right? And each RM HAS a TCP port assigned, right? Then when configuring RM cluster you must specify which TCP Port is using each RM. Member ID 1 is RM 1 and Member ID 2 is RM 2.
HTH
Offline IF
« Reply #2 on: June 15, 2011, 09:03:55 PM »
It's now quite accurate to say that this port is "each RM HAS a TCP port assigned". It's very easy to get confused and think that the port is the usual SIP Port 5060.
You should better read the deployment guide instead of just reading the options' description from GA.
Typically, the cluster section of each RM should look like the following (for active-standby mode):
[cluster]
electiontimer=3000
failoverscript=$InstallationRoot$/bin/NLB.bat
ha-mode=active-standby
heartbeattimer=2000
hotstandby=true
member.1=10.228.194.210:9801
member.2=10.228.194.209:9801
members=1 2
mymemberid=2
networkrecoverytime=5000
virtual-ip=10.228.101.39
So, the port for which you wonder about is the 9801. You can chose any other unoccupied port but the 9801 is kind of "standard" port and recommended to keep. You should change it though if on the same server with RM you have an SSG installed (due to 9801 used for https). Also, please keep in mind that member.2 is the Primary and member.1 is the Backup. And whenever member.2 RM is started it goes always to Primary. There is not the usual Genesys notion of Primary/Backup/switchover here. If you have member.1 started and member.2 stopped and then you start member.2, then it goes automatically to Primary mode - no surprises here  ;D
But, please, read thoroughly the manuals - otherwise it doesn't make sense to explain more.
Kind Regards,
IF
