" /> ACW for Outbound Calls Only? - Genesys CTI User Forum
Author Topic: ACW for Outbound Calls Only?  (Read 5494 times)
Offline amarceau
« on: June 09, 2011, 12:15:09 PM »
Can anyone help me with creating this statistic?
I've found in the Reporting Technical Guide two statistics that sound like they are exactly what I need - but I'm running into issues.  I created this statistic:
ACW_Time_Outbound
MAIN MASK AfterCallWorkOutbound
CATEGORY TotalAdjustedTime
SUBJECT DNStatus
OBJECT TYPE(S)  Agent, Place, GroupAgents, GroupPlaces
But in the description of this statistic - it says the following:
This stat type excludes durations of voice interactions placed on hold by
the agent. This statistic excludes the related after call work time. This
statistic also [u][b]excludes the time spent on the outbound voice interactions
that are part of outbound campaigns[/b][/u], including ASM.
So obviously based on this description all my ACW time that an agent works on a Campaign is not being calculated anywhere.  But I still need this ACW_Outbound statistic, so anyone know how I can get it?  I thought of just using the Total_ACW statistic and applying a filter for CallOutbound, but that doesn't seem to be working either.
Any suggestions?
Offline Steve
Re: ACW for Outbound Calls Only?
« Reply #1 on: June 09, 2011, 01:03:33 PM »
WE use -
ACW_TotalTime_Outbound
CATEGORY TotalTime
SUBJECT AgentStatus
OBJECT Agent, Place, GroupAgents, GroupPlaces
& ACW_AverageDuration_Outbound
CATEGORY AverageTime
SUBJECT AgentStatus
OBJECT Agent, GroupAgents
Offline amarceau
« Reply #2 on: June 09, 2011, 01:38:31 PM »
Steve - do your agents work outbound Campaigns?  The statistic you indicated you are using is the same statistic I tried, but it is not incrementing for my Outbound Campaign time.  And according to documentation this statistic will "exclude" Campaign Outbound calls.
Offline Steve
« Reply #3 on: June 10, 2011, 11:46:37 AM »
Yes they do outbound campaign dialling.
I've just opened Pulse they are not doing OB today. But I'm sure it works, if it didn't someone would have complained by now ;)
Offline amarceau
« Reply #4 on: June 14, 2011, 04:31:59 PM »
Steve -
Had a chance to see if your ACW_Outbound statistic is calculating Campaign Outbound Time?
I've still been playing with this for a week now and cannot get this statistic working.
« Reply #5 on: June 14, 2011, 11:22:34 PM »
What does StatServer says?
Offline amarceau
« Reply #6 on: June 20, 2011, 04:38:33 PM »
all - It's ok -- got this working.  Thanks.  Ended up having to attach data from softphone that would tell statserver if call was inbound or outbound & then create a custom statistic with filter to get the ACW_Outbound and ACW_Inbound.
I can't believe Genesys would have a statistic for ACW_Outbound but that EXCLUDES calls made on a Campaign???  Very odd indeed.
Adam G
« Reply #7 on: June 28, 2011, 09:29:50 AM »
I think I might be able to shed some light on this...
An Outbound Campaign Call is actually an Inbound Call to the Agent, because the call is connected [i]from [/i] the Switch [i]to [/i] the Agent....
If an Agent picks up their handset/softphone and dials a Number, [i]that [/i] is an Outbound Call...
- I think you have probably done the right thing to add in a KVP to determine Inbound calls and seperate them from Inbound Campaign Calls...
Hope this helps?
TT
Offline Steve
« Reply #8 on: June 29, 2011, 05:05:42 PM »
There is something wrong here, the stats for ACW_Outbound count calls where the call type is outbound, this should include campaign calls. Even though the calls are presented to the agent as an inbound call, they should be tagged properly as outbound.
« Reply #9 on: June 29, 2011, 07:26:06 PM »
Totally agree, that is why is important to check ss logs...
