" /> Send DTMF function on Outbound calls and consulting transfer - Genesys CTI User Forum
Author Topic: Send DTMF function on Outbound calls and consulting transfer  (Read 4175 times)
Offline amakarevskij
Good day!
I need use function "Send DTMF", but it work only in inbound calls!
I call this function from Siebel CRM with GPlus adapter within Siebel code.
In The SIP Server log and Stream Manager log - all is ok  - client disconnected from agent and connected to stream manager and DTMF has played, but no DTMF sound if call is outbound or consultative transfer!
(The problem - automatic DTMF send to external number to consult agent with specialist in other company, according to the selected call purpose)
Sorry for my very bad English.
Re: Send DTMF function on Outbound calls and consulting transfer
« Reply #1 on: June 03, 2011, 10:50:33 AM »
The problem has been solved -
Stream Manager's options
sip-dtmf-method
set to "tone"
Offline HeatherTamblyn
« Reply #2 on: June 03, 2011, 11:28:13 AM »
How did you get it solved? Have you read some journal?
