" /> Call drop on 8th seconds - Genesys CTI User Forum
Author Topic: Call drop on 8th seconds  (Read 3321 times)
Offline cpoon
« on: May 30, 2011, 08:44:47 AM »
Hi
I'm using SIP Server 8.0 with X-Lite 4.0, somehow the call always dropped at the 8th second. I went through the logs and noticed this:
Reason: SIP;description="media stream error: 8008"
Any idea what's this is about?
thanks in advance,
cp
Re: Call drop on 8th seconds
« Reply #1 on: May 30, 2011, 06:03:03 PM »
Hi cpoon,
This error means there are some troubles related to RTP stream. Is this error generated by Stream Manager?
PS. X-Lite 4.0 has not been officially tested with SIP Serve thus it might not work correctly. I would suggest you using supported SIP soft phone for testing...
