" /> Agent capacity - Genesys CTI User Forum
Author Topic: Agent capacity  (Read 4693 times)
Offline smile
Agent capacity
« on: May 25, 2011, 02:15:36 PM »
Hi All
I faced with interesting trouble: there is a agent group in environment. Every agent in it and place for corresponding agent has capacity rule assigned for voice and chat. Some of the agents logged in with voice channel only (or with voice&chat, but voice state is Ready and chat state is Not Ready), some of them is logged in with voice&chat=Ready.
The thing is that agent state (ready/not ready) is considered according to state of voice channel! More over, if agent is logged in only to voice without multimedia and agent is in Ready state, then statserver returns Ready state for URS when multimedia distribution is executed.
This result in to: even my agent is ready for voice and they didn't log in to multimedia channel, URS will distribute multimedia interaction for him. CCPulse even doesn't show multimedia channel for such agent, because this agent logged in only for voice. But capacity snapshot shows that agent has routable chat interactions according to capacity rule!
From statserver user's guide i'm aware on that place status is taken from status of voice DN. That's why statserver/urs tries to route multimedia interactions to incorrect targets.
But, reasonable question is: is it possible to check media availability for agent and its correspondence to media type of interaction automatically? the one solution that i see is to build dynamic target group based on media statistic for current interaction.
Any suggestions, please help.
Offline kubikle
Re: Agent capacity
« Reply #1 on: May 25, 2011, 07:39:26 PM »
URS normally checks media availability automatically (if explcitely not forced not to do it with functions/options like UseDNType).
Does chat interactions is sent to one of agents voice DNs (extensions, etc) or to agent directly (= what is inside requestroutecall)?
Any snippet from URS log covering receiveing evnt from statserver about agent state changing (CHANGE OF STATE message)?
Offline smile
Re: Agent capacity
« Reply #2 on: May 26, 2011, 06:58:20 AM »
i'll check logs and share information. but i consider requestroutecall doesn't has matter because at that moment agent was already selected and this agent is wrong for multimedia interaction. For testing purpose i'm using simple chat strategy from mcr samples.
