" /> Problemes on the Qinfo table - Genesys CTI User Forum
Author Topic: Problemes on the Qinfo table  (Read 2228 times)
Offline catvrom01
« on: May 18, 2011, 01:59:27 PM »
Hi
I see that we have a problem on the qinfo table.
The  startTime = 1294676817
The  endTime=  1294676817
[b]But the  Duration=1( and must be 0).[/b]
In the documentation of StatServer i see:
StartTime A sequence number representing the date and time when the status displayed in
the Status field (of this table) began. The sequence begins with January 1, 1970,
12:01 AM UTC and increments every second. For example, 878159351
represents October 29, 1997, 13:09:11. Each new second represents an increment
of 1 in the sequence.
The duration, in seconds, of the status displayed in the Status field
Status. The status of the transition of a call through a queue whose DBID is displayed in
the QueueDBID field (of this table). (Table 15 below lists possible values.)
EndTime A sequence number representing the date and time when the status displayed in
the Status field (of this table) ended. The sequence begins with January 1, 1970,
12:01 AM, UTC, and increments each second. For example, 878159351
Whay is the explanation that the Duration=1 and not  0?
Re: Problemes on the Qinfo table
« Reply #1 on: May 18, 2011, 02:24:51 PM »
That it was a event that took place in milliseconds and round will give 1 but as timestamp doesn't save ms you will see same time, check your logs to analyze
