Author Topic: Load increase on Statserver?  (Read 2019 times)
Offline S
« on: May 16, 2011, 05:20:04 PM »
Which of the cases would overload the statserver version8
1) I have some RPs use certain set of Stats... If I add bunch more RPs to the Env... using the same set of stats ...
2) Some RPs using certain set of Stats, and I add bunch of some more Stats  for these RPs ...
3) this case, I add more RPs and more Stats ...
I am thinking the 3rd case- would definitely overload the statserver... how about the first two cases...??
anyone has any ideas or suggestions?
tony
Re: Load increase on Statserver?
« Reply #1 on: May 16, 2011, 05:32:09 PM »
Any of them, since it also depends on the frequency of requests - i.e. how often are the Objects>Stats called....
T
