" /> SIP Server for GVP8 - Genesys CTI User Forum
Author Topic: SIP Server for GVP8  (Read 8671 times)
SIP Server for GVP8
« on: May 12, 2011, 04:01:05 PM »
Hi guys,
I'm planning a deployment for GVP8...still no training but reading all the documentation I can find...
I have a little question, GVP8 says it needs SIP Server, but does it means it has its own SIP Server (as stated on Deployment Guide) or does it means that it needs Genesys SIP Server (with Tserver facilities)??
If second...why?? If I already have a GVP 7.6 deployed with its IVR Server and PBX Tserver why do would I need a SIP Server?
Thanks for any pointers here...
Offline minuteman
Re: SIP Server for GVP8
« Reply #1 on: May 12, 2011, 11:44:57 PM »
GVP8 is SIP-only solution, so it definitely needs Genesys SIP Server. Also subset of GVP8 components (Resource Manager and Media Control Platform) may be used as Media Server for Genesys SIP Server (in place of Stream Manager, for conferencing, transcoding, etc.).
« Reply #2 on: May 12, 2011, 11:57:55 PM »
Well GVP 7.6 also was SIP and no SIP Server was needed at all...
Thanks for the input tho
Offline smile
« Reply #3 on: May 13, 2011, 02:51:17 PM »
cavagnaro, you can use stream manager without sip server isn't? ;) i mean case when you can take e.g. asterisk and connect them to stream manager. you can do the same thing with gvp8, it looks like in-front scheme, but without sip server, urs and agents. you can claim that such configuration is unsupported, and it's true. but you can build this ;)
Offline Fra
« Reply #4 on: May 16, 2011, 08:47:47 AM »
[quote author=cavagnaro link=topic=6423.msg27932#msg27932 date=1305216065]
Hi guys,
Cav,
in essence Genesys is pushing for a whole SIP-based solution; the integration between GVP and Framework on one side and the gateway on the other is done via SIP Server, so that basically you get back to having GVP working in behind mode, like we used to go for years with a premise IVR :)
You can still try to integrate GVP 8 via IVR TServer & CTI connector without SIP Server (so that GVP looks like deployed in network mode) but this is not how GVP 8 was ideally designed for.
Take a look of the GVP Deployment guide and especially of  VPS 8 Integration guide.
Fra
Offline creading001
« Reply #5 on: May 16, 2011, 12:00:13 PM »
You need SIP server - it is not that difficult to deploy. Resource Manager is optional.
Offline Fra
« Reply #6 on: May 16, 2011, 12:21:50 PM »
[quote author=creading001 link=topic=6423.msg27946#msg27946 date=1305547213]
I don't think Cav has any issues in deploying a Genesys app :)
It's not optional in v8.
Fra
« Reply #7 on: May 16, 2011, 02:31:05 PM »
[quote author=Fra link=topic=6423.msg27941#msg27941 date=1305535667]
Hi guys,
Cav,
Fra
Yup Fra, already read it all and seems possible but not supported, so if I face any issues I'll probably have issues with support team accepting my requests...
For what I can see I have 2 options:
SIP Server transfer the call to a SIP Routing Point and then invoke GVP
SIP Server transfer the call to GVP and then use a Route Request to transfer to other TServer
Now I have to see how to integrate my Alcatel TServer with SIPServer to do a proper ISCC integration and transfer between them...time to play :)
« Reply #8 on: May 16, 2011, 02:33:46 PM »
As Fra says, this is not the problem, I see SIP Server since some time ago without many issues...my question was mainly because of architecture changes over 7.x to 8.x
About RM on GVP 8.x as Fra also says, it is not optional, on 7.x it was.
Offline Fra
« Reply #9 on: May 16, 2011, 03:30:45 PM »
They should be supporting this integration, as they mention it - I would say, they would not recommend it.
Correct, you should just do a classic multisite integration via ISCC, it shouldn't be hard ;)
Fra
« Reply #10 on: May 20, 2011, 01:06:07 AM »
Ok, I did it! :D Works fine but I found some "issues"...
1. I integrated my SIP Server with my OXE (2 TServers)
2. Call is received on SIP Server
3. A SIP Server RP targets OXE agents
4. OXE agents receive calls with attached data
Questions:
1. When I put the call on hold the SIP Server music is used...not the OXE one
2. When finish the call SIP Server ACW is used, again, not the OXE settings...
Is there any chance to change this? Or maybe route to an OXE Routing Point instead and let OXE then control that RP?
« Last Edit: May 20, 2011, 03:55:04 AM by cavagnaro »
Offline Fra
« Reply #11 on: May 20, 2011, 11:44:07 AM »
[quote author=cavagnaro link=topic=6423.msg27989#msg27989 date=1305853567]
Questions:
I'm unsure about how your solution looks like now..
[list]
[li]Do you mean you have a SIP trunk between SIP Server and OXE? Is OXE acting just like a gateway or like a separate switch?[/li]
[li]Are your agents SIP Server ones or OXE / TServer ones?[/li]
[li]Do you mean a Stream Manager treatment?[/li]
[/list]
Fra
« Reply #12 on: May 20, 2011, 01:34:52 PM »
Yes, a SIP Trunk is used from SIP Server to OXE
My agents are OXE agents only, no DNs on SIP Server, just RP
No StreamManager
Offline taz
« Reply #13 on: May 20, 2011, 06:01:02 PM »
we have gvp8 implemented w/o sip server.  it's not required.
« Reply #14 on: May 20, 2011, 06:34:53 PM »
Can you please indicate how is your configuration done? Architecture and basically how to sent Attach Data to your PBX TServer?
Thanks!
