Author Topic: Creating a Virtual Agent Group with a choice of Skills  (Read 2525 times)
Offline TLizotte
« on: April 27, 2011, 06:54:36 PM »
Hi again.
I'm trying to create a VAG based on whether an agent has Skill A >=1 [b]or[/b] Skill B >=1 and it doesn't seem to like it.  When I use the "&" feature between the skills works fine.  Is there different syntax I should be utilizing or is this just not possible?
Re: Creating a Virtual Agent Group with a choice of Skills
« Reply #1 on: April 27, 2011, 06:56:18 PM »
Try with | symbol. OR would be for AND not for &
Offline TLizotte
« Reply #2 on: April 27, 2011, 07:04:04 PM »
Thank you from the Newbie!
