Author Topic: Can I look for The user who made changes in CME?  (Read 3784 times)
Offline Mat
« on: April 26, 2011, 07:54:04 AM »
I nedd look for the user who make changes skills
can I see that information in logs or in any table
Thank's
Offline ag0059111
Re: Can I look for The user who made changes in CME?
« Reply #1 on: April 26, 2011, 12:37:09 PM »
[quote author=Mat link=topic=6391.msg27780#msg27780 date=1303804444]
Thank's
Yes you can see that either through Log Database or ICON DB
Offline Mat
« Reply #2 on: April 26, 2011, 01:40:14 PM »
I'm going to trie  find in LogDatabase if you can please help me with the tablename. Iwould be grateful for it
Offline bandorka
« Reply #3 on: April 27, 2011, 07:37:47 AM »
...or you can find it in the config server logs...
Bandorka
Offline creading001
« Reply #4 on: April 27, 2011, 08:50:34 AM »
Try this link ....
http://genesysguru.com/blog/blog/2010/02/19/who-changed-that-cme-object/
Craig
Offline fnunezsa
« Reply #5 on: April 27, 2011, 06:17:52 PM »
Please refer to Management Layer User Guide for instructions on how to set up Audit Trail for Configuration Server.
In brief, you need to:
1) Include the value "network" in Config Server log options.
2) Include option print-attributes=true in Config Server configuration file.
2) Allow Message Server to write to the LOG DB.
Please note that Log DB does not have an automatic purging procedure so you will have to set one up. Also, the size of you Log DB depends on the level of log you'll be writting. Please refer to Genesys Sizing guide for guidance on how to estimate the size of you Log DB.
Basically, log messages are written to g_log_messages and messages attributes are written to g_log_attr.
Offline Mat
« Reply #6 on: April 28, 2011, 07:50:01 AM »
Thank you very much for all to every body.
Whith your help I will can configure the enviroment for Audit Config Server
Regards
