" /> upgrade GVP 7.6 - Genesys CTI User Forum
Author Topic: upgrade GVP 7.6  (Read 3391 times)
upgrade GVP 7.6
« on: April 08, 2011, 05:01:11 AM »
Hi guys,
I'm planning to upgrade the GVP Core components and the EMPS...any points on how to do this? I can't find a procedure for this...
Thanks!
Offline bandorka
Re: upgrade GVP 7.6
« Reply #1 on: April 08, 2011, 07:02:29 AM »
Hi Cav,
I think, and if I'm right you have two ways:
1: follow Chapter 11 from the deployment guide
2: manually: you should uninstall components the reverse order and then install hot fixes
Bandorka
Offline smile
Re: upgrade GVP 7.6
« Reply #2 on: April 08, 2011, 08:51:31 AM »
Hi All
by the way, how i can uninstall component (e.g. obnmanager) from gvp?
Offline bandorka
Re: upgrade GVP 7.6
« Reply #3 on: April 08, 2011, 03:02:14 PM »
with your windows uninstaller, just care about your ldap db
Bandorka
Offline smile
Re: upgrade GVP 7.6
« Reply #4 on: April 08, 2011, 03:14:06 PM »
=) but in case of unix? how to remove config of service from ldap? watchdog still tries to run it...
Offline Steve
Re: upgrade GVP 7.6
« Reply #5 on: April 08, 2011, 04:14:15 PM »
I'm not a GVP expert would imagine that you stop watchdog first.
[code]$ ps -ef | grep watchdog[/code]
to find the processID, then the command below to stop it
[code]$ kill -9 xxxxx[/code] were xxxxx is the processID
Re: upgrade GVP 7.6
« Reply #6 on: April 08, 2011, 04:23:50 PM »
:o Well tried with the Core Components  (at lab) and WAF! all configuration gone and gvp.ini was deleted along with all GVP/CN folder...by luck it was lab and have a backup but now it is not letting me reinstall....sucks! I guess will have to do something with the OpenLdap as it was not removed...
Really sucks this update process....using GDT is not always possible as I installed all components by hand first time...
