" /> Cisco UCM Version8 - Genesys CTI User Forum
Author Topic: Cisco UCM Version8  (Read 2218 times)
Offline nickers
Cisco UCM Version8
« on: April 06, 2011, 03:38:52 PM »
Hello All
Has anyone out there been 'lucky' enough to get to play with Genesys and Cisco UCM version 8?
We are shortly upgrading UCM from version 6 (with 7.6 T-Server), to version 8 and I was wondering whether there were any major issues to look out for.
I understand that we will need to upgrade the T-Server to minimum 8.0.1 version, but as this is Genesys, I can't believe it is as easy as that!
Anyone able to shed some light, or share some experience?
Many thanks!
Offline smile
Re: Cisco UCM Version8
« Reply #1 on: April 07, 2011, 07:13:25 AM »
well, we play with CUCM version 7 and T-Server version 8. also we have a plan to upgrade CUCM to 8, but don't know when it will exactly occurs.
Offline nickers
« Reply #2 on: April 07, 2011, 08:12:13 AM »
Thanks for the reply!
Well, if we get to go first, I'll keep you posted on any issues or 'challenges' that we encounter...
N.
Offline smile
« Reply #3 on: April 07, 2011, 08:16:01 AM »
[quote author=nickers link=topic=6325.msg27570#msg27570 date=1302163933]
N.
thank you, will wait for your results. good luck! ;)
