" /> Reg: Call Routing - Genesys CTI User Forum
Author Topic: Reg: Call Routing  (Read 1737 times)
Offline JJR
Reg: Call Routing
« on: April 05, 2011, 11:26:42 PM »
One agent is not receving the calls though he is logged into smartphone and in ready state. Other users able to receive the calls with same skill and configuration as the agent not able to receive the calls. Could you please let me know how can we fix this issue.
Any information will be appreciated.
Thanks - JJR
Offline Timur Karimov
Re: Reg: Call Routing
« Reply #1 on: April 06, 2011, 06:47:48 AM »
Do you read about standard RONA capatibilities ?
Offline fnunezsa
« Reply #2 on: April 06, 2011, 03:42:55 PM »
Can you provide more details? Call flow? Routing strategy design? It seems like you sttrategy is not identifying that agent as a possible target. You should look at your URS logs to figure out why. Have you tried routing to that agent's place, meaning a simple strategy that targets that agent's place?
Offline Steve
« Reply #3 on: April 06, 2011, 03:55:54 PM »
Restart your T-Server and Routing Stat-Server. We find this happens quite a lot, especially when an agents config has been changed.
