Author Topic: Infomart / StatServer AHT discrepancy  (Read 7792 times)
Offline Adam_W
« on: March 31, 2011, 06:30:33 PM »
Yet another Infomart post; you can tell I'm slightly out of my depth here!
I'm working with a customer who uses WFM and Infomart/Interactive Insights for reporting.  There is an issue over the difference in Average Handle Time calculation over the course of a day.
WFM obtains its statistics from StatServer whereas Infomart works with events from T Server, so to an extent I would expect a difference in the figures, but its a sticking point in this case.  We've narrowed the difference down to 15-20 seconds per day by trying to make the calculations the same between the two sources, but the desire is that they will be exactly the same.
It's interesting that it's 15-20 secs each day and suggests there may be something I'm missing in the calculation.  I have no idea what.
Just interested to see whether anyone else has every tried to overcome the same challenge?
Offline mhsoomro
Re: Infomart / StatServer AHT discrepancy
« Reply #1 on: February 25, 2016, 07:37:49 PM »
I am also facing the same issue with my customer. If IWS KPI from Stat server is showing 2:52 AHT then at the same time interactive insight report showing 3:58 AHT.
Please Help
Offline mhsoomro
« Reply #2 on: March 05, 2016, 07:38:37 AM »
R we going to get any response on this.
Offline nonny
« Reply #3 on: March 06, 2016, 04:35:54 AM »
http://www.sggu.com/smf/index.php?topic=9099.0
Sent from my SM-N9005 using Tapatalk
Adam G
« Reply #4 on: March 06, 2016, 09:04:17 AM »
[quote author=Adam_W link=topic=6310.msg27480#msg27480 date=1301596233]
OK.... here we go again.... deep breath, aaaand... :)
A StatServer gets it's info through being connected to a TServer.  Your statement that "WFM uses a StatServer and Infomart uses a TServer" is correct but Infomart uses an element called ICON to extract statistical data from a TServer.  So, in actuality, the source of the stats for both solutions is a TServer - but the path to extracting the stats is not quite the same.
There isn't a matrix of comparable units for the statistics across CCA|GI2|CCP|WFM|IWS because they all serve different purposes;
CCA, CCP and IWS generally count Volumes
GI2 generally counts Interactions
WFM generally counts Work Effort
Next, the way in which stats are calculated across these [i]different solutions [/i]is not the same.  With one, it may calculate AHT based on whole numbers only (13 seconds) - whereas another may count the absolutes (12.56 seconds).
Finally, as a rule of thumb and a [i]Best Practice[/i], even using the same Platform which has 2 separate reporting sources, you should allow for up to 3% differential between stats.  You are looking for everything to be mathematically equal and - whilst it may be very satisfying to see that - it will not be.  In actual fact, without even knowing what your volumes are, if you have a differential of [i]only [/i]15-20 seconds in AHT for day, that is [i]extremely [/i]accurate!
If you take anything away from this post, let it be this;
Genesys is [u]not [/u]a [i]Solution[/i].  It is a [i]Platform[/i].  It can contain many different Solutions which were built with specific tasks in mind.  Ask yourself if you are using those Solutions for the individual purposes they were intended - or you are trying to manipulate data sets from different Solutions purely because you think you can.  The volumes, counts, statistics, averages and other calculations and algorithms within each Solution are applied to thousands - sometimes millions - of units for measurement, so there are bound to be some small scale differences.  So, really - [u]don't sweat the small stuff[/u], it will be a fruitless effort for very little gain.
Adam
Offline mhsoomro
« Reply #5 on: March 16, 2016, 06:47:17 AM »
OK, 3% differential is acceptable but 20% to 30 % difference is not acceptable anywhere in industry. let me tell you what we are facing in difference.
[b]GII Report output:[/b]
Agent Name Accepted Avg Handle Time       Engage     Hold         Wrap
Agent 1 Inbound 81         0:02:17                 0:02:11 0:00:00 0:00:06
Agent 2 Inbound 54         0:02:08                 0:01:42 0:01:09 0:00:23
Agent 3 Inbound 71         0:04:35                 0:03:48 0:00:42 0:00:39
Agent 4 Inbound 24         0:03:03                 0:02:15 0:01:11 0:00:16
Agent 5 Inbound 103       0:02:31                 0:02:21 0:03:14 0:00:08
Agent 6 Inbound 81         0:03:31                 0:02:55 0:02:13 0:00:15
Agent 7 Inbound 80         0:02:56                 0:02:36 0:00:53 0:00:07
[b]Agent IWS KPI's:[/b]
Agent Name Calls AHT
Agent 1         81 2:16
Agent 2         54 2:03
Agent 3         71 3:52
Agent 4         24 1:58
Agent 5         103 2:29
Agent 6         81 3:00
Agent 7         80 2:23
Above both are only Inbound results as this call center does not have outbound option. Some agents are having minor difference but most of them having major difference.
Below i will tell you the formula used in GII report for AHT and formula used in IWS_StatServer Stat of AverHandleStatusTime
[b]GII Report AHT Formula:[/b]
sum(AG2_AGENT_DAY.ACCEPTED) )+(
sum(AG2_AGENT_DAY.CONSULT_RECEIVED_ACCEPTED) ))<>0
then 1.0*( (
sum(AG2_AGENT_DAY.ENGAGE_TIME) ) + (
sum(AG2_AGENT_DAY.WRAP_TIME) ) + (
sum(AG2_AGENT_DAY.HOLD_TIME) ) + (
sum(AG2_AGENT_DAY.CONSULT_RECEIVED_ENGAGE_TIME+AG2_AGENT_DAY.CONSULT_RECEIVED_HOLD_TIME) ) + (
sum(AG2_AGENT_DAY.CONSULT_RECEIVED_WRAP_TIME) ) + (
sum(AG2_AGENT_DAY.CONSULT_RCV_WARM_ENGAGE_TIME+AG2_AGENT_DAY.CONSULT_RCV_WARM_HOLD_TIME) ) + (
sum(AG2_AGENT_DAY.CONSULT_RCV_WARM_WRAP_TIME) ) )/((
sum(AG2_AGENT_DAY.CONSULT_RECEIVED_ACCEPTED) )) else 0 end
[b] IWS_StatServer Stat of AverHandleStatusTime:[/b]
Category: "AverageTime"
MainMask: "CallInBound, AfterCallWork, CallInternal, CallConsult, CallOnHold"
RelMask: "CallInBound"
Subject: "AgentStatus"
Now please help us matching atleast with 3% difference. Please note that i can only change the IWS Stats values.
« Last Edit: March 16, 2016, 07:10:26 AM by mhsoomro »
Adam G
« Reply #6 on: March 16, 2016, 11:30:16 AM »
You might want to take a look at the definitions for the IWA "ACW" versus the GI2 "Wrap".
Even better, you can extrapolate each parameter (Inbound vs. Engage, Hold vs. Hold and ACW vs. Wrap) and compare them on their own, to see where the anomaly is.
Offline mhsoomro
« Reply #7 on: March 16, 2016, 12:07:04 PM »
I have been trying but no success.
Adam G
« Reply #8 on: March 16, 2016, 01:06:01 PM »
Not much else I can advise but keep bringing things back to their basics and compare pure stats from each solution... you are bound to come across the anomaly at some point.
One thing I did notice: CallInBound is not a generic/pure stat name - it's CallInbound (no capital "B").  You might want to take a look at that...
« Last Edit: March 16, 2016, 01:11:02 PM by adamgill »
« Reply #9 on: March 16, 2016, 01:34:47 PM »
Just did and doesn't work. Help me fix it.
Offline mhsoomro
« Reply #10 on: March 16, 2016, 02:01:26 PM »
Capital B was a typo here. On production, it's small b.
Adam G
« Reply #11 on: March 16, 2016, 03:18:19 PM »
[quote author=cavagnaro link=topic=6310.msg42709#msg42709 date=1458135287]
« Reply #12 on: March 16, 2016, 03:24:54 PM »
[quote author=adamgill link=topic=6310.msg42713#msg42713 date=1458141499]
Lol anticipating the OP answer
Adam G
« Reply #13 on: March 16, 2016, 03:28:24 PM »
[quote author=cavagnaro link=topic=6310.msg42714#msg42714 date=1458141894]
« Reply #14 on: March 16, 2016, 04:49:04 PM »
Told you, nothing new on how to help him ;) Do magic stuff  ;D
