Author Topic: Alarm History in SCI  (Read 4010 times)
Hello, all, how are you?
I wanted somebody to check for me if they could confirm that alarm history is in fact not being written or shown in SCI.
I have several active alarms shown on the screen, but none of them show up in alarm history section.
Can someone please tell me if I am missing some important option, or is it a bug?I can see trace log and standard log but no alarm log.
SCI version I am using is 6.1.000.12.
Marked as best answer by on September 12, 2024, 01:28:10 AM
Tiina
  • Undo Best Answer
  • Hello Vic,
    I use exactly the same version of SCI as you are and I can see all these history information (alarm, trace and standard).
    Hmm What to do? First of all you should run a Management Layer Troubleshooter Wizard and check that you have the right configuration.
    You find that Wizard in SCI's toolbar, the second tool at right hand side (Run a Wizard).
    Good luck,
    Tiina
    Ritchie
    Did you find out what was wrong Vic?
    Ritchie
    Hey Vic, found the solution! Add 'network' to the logging options on the Solution Control Server app in CME.
    Hey presto...
