" /> Genesys Reporting Accuracy - Genesys CTI User Forum
Author Topic: Genesys Reporting Accuracy  (Read 3810 times)
Offline PFCCWA
« on: January 28, 2011, 12:25:52 PM »
Following a recent deployment of a genesys solution we have occurred problems by which reporting is never match to 100%.
A typical example involves calls entered at route point level are never always accounted for. On some days we will see a match, others will see a difference of 1-5.
Without breaking the routing up to determine where the missing calls could be, it seems very difficult to capture that 1 'rogue' call in a period of thousands.
I am wondering whether other users experience the same issue following a deployment and whether they accept the handful of calls missing or work towards a 100% match?
WA
Re: Genesys Reporting Accuracy
« Reply #1 on: January 28, 2011, 06:33:58 PM »
Which PBX are you using? Maybe Nortel???
Offline PFCCWA
« Reply #2 on: January 28, 2011, 08:33:33 PM »
Avaya with SIP
« Reply #3 on: January 29, 2011, 05:21:34 AM »
So you use Avaya as a MediaGateway with SIP TServer or what?? Maybe some more detail description of your infrastructure and call flow can be helpful and also LOGS!!
