" /> Longest Available Agent - Genesys CTI User Forum
Author Topic: Longest Available Agent  (Read 9423 times)
Dan Percy
I am trying to do some routing based on Longest Available Agent. I am using an Aspect switch and have been trying to monitor an agent group defined in the switch. I have not been able to get any events from this switch defined group via Genesys. Is this even possible ? Any other ideas for receiving LAA on Aspect ?
Bartacus
In your strategy, perform agent selection "Based on Statistics" , and use the stat "StatTimeInReadyState". This will select the agent that's been waiting/ready the longest.
Carlos Alanis
Just remember an Agent can cheat this making a quick logout/login....
Offline robert_rudman
Re: Longest Available Agent
« Reply #3 on: January 14, 2009, 12:13:08 PM »
I'd like to know more about an agent can cheat this with a quick logout/login?
Do you mean by logging out/in they can avoid calls? Please explain.
Marked as best answer by on Yesterday at 08:34:48 AM
mike kamlet
« Reply #4 on: January 14, 2009, 02:23:10 PM »
  • Undo Best Answer
  • If the stat you are using is "most idle agent" then the agent that has been in the ready state for the longest amount of time will get the call.
    In a non-busy environment, if an agent quickly hits not-ready/ready they essentially reset their clock.  Instead of being in a ready state for 1 min, they are only ready for 1 sec since they had changed to not ready.
    There's no need to log out, nor does the agent need to stay in a not-ready state for any measurable length of time.
    Avaya has a method to route to least occupied agent (where they use agent occupancy as the stat) -- there are drawbacks to that approach as well..
    Offline catanirex
    « Reply #5 on: January 14, 2009, 04:36:43 PM »
    Have you checked out StatAgentLoading statistic?
    It is used to select agents based on current agent loading
    Offline gustav
    « Reply #6 on: January 19, 2009, 09:37:26 PM »
    Create a custom statistic for 'TimeSinceLastCall' which resets the timer based on the time the agent last received an inbound call, vs, time in Ready state.  This prevents agents from going 'ready / not-ready' to beat the system, or agents calling eachother to 'knock eachother out of agent queue'.
    As for the switch defined groups, if they are not dynamic, could you not create a physical group in Genesys to mirror the switch group.
    Offline Fouad douhan
    « Reply #7 on: April 24, 2016, 03:42:15 PM »
    [quote author=mike kamlet link=topic=612.msg15965#msg15965 date=1231942990]
    Avaya has a method to route to least occupied agent (where they use agent occupancy as the stat) --[glow=red,2,300] there are drawbacks to that approach as well..[/glow]
    What are the drawbacks to that approach?
