" /> Reporting Templates - Genesys CTI User Forum
Author Topic: Reporting Templates  (Read 5291 times)
Offline PFCCWA
Reporting Templates
« on: January 04, 2011, 09:56:14 PM »
I am curious as to finding out how Genesys users build their historical (or real time) reporting templates?
Do you have canned reports available upon deployment ie hyperion?
We are using business objects company wide including Genesys but wondering if reporting templates exist as a starter or base to develop.
WA
tony
Re: Reporting Templates
« Reply #1 on: January 18, 2011, 12:27:27 PM »
Hello again.... :)
The Hyperion installation comes with a standard set of Reports, specifically for Genesys.
As I recall, there is also a "Report Generation Assistant" (RGA) Hyperion Template - basically, you select your Objects (Agent, Agent Group, Queue, Route Point, etc.), then specify the Stats you want and the Aggregation Level and it produces a pre-defined Hyperion Report for you.  The only problem with the RGA is if you mess around with the CCA Database (Datamart) Tables and Views or add new Layouts in DMA - it doesn't recognize anything apart from the standard build...
The basis for any Query is to find the 3 Tables from the same DMA Layout which include the Objects, Statistics and Time - usually the T_, O_ and R_  Tables in your Datamart.  For example (names may or may not reflect these values);
T_noagg_Agent_Group
O_noagg_Agent_Group
R_noagg_Agent_Group
(the naming conventions are closely tied to the DMA Layout names...)
Connecting the Tables:
O_ to R_ Tables = ObjectID
R_ to T_ = Time Key
Selecting criteria:
From the O_ Table, you might want to use either the PresentationName or the ObjectName - both are similar
From the R_ Table, select the Statistics you want to see on your Results.
From the T_Table, select something like Date_yymmdd to select a date.
Constrain/Optimize your Query criteria:
The Datamart Tables can grow very very big (millions of rows) and, depending on your Database type (SQL or Oracle), your Query may or may not be optimized before it hits the db.  So - bear in mind you want to constrain your Query from the outset and make an educated guess at which part of your Query will constrain the results the most.  For example;
If you are querying a "no agg" Table, constrain that first - this will mean the Query will extract a small portion of the db Table, prior to applying any other criteria.
Next, work out which will constrain that extract the most - do you have relatively more Stats - or Objects?  If you are requesting 10 Stat Types and 30 Objects ("Agents), then send the Stat Types before the Agents within your Query.  With these as example, it might look something like:
SELECT [i](Objects, Stats, Times)[/i]
FROM[i] (T_, O_ and R_ Table References)[/i]
WHERE T_no_agg_Agent_Group.Date_yymmdd = "110118"
AND O_no_agg_Agent_Group = "AG1" OR "AG2" OR "AG3" OR "AG4" OR "AG5" OR "AG6" OR "AG7" OR "AG8" OR "AG9"OR  "AG10"
- in this way, the db engine has the least work to do, even if there are no optimization techniques applied on it.
Phew! :) - hope this helps?
TT
« Last Edit: January 18, 2011, 12:34:42 PM by Tony Tillyer »
Offline smile
« Reply #2 on: January 18, 2011, 01:14:10 PM »
extremely useful manual, Tony!
« Reply #3 on: January 18, 2011, 04:09:16 PM »
Very nice! I will translate it and use it for new comers :) Thanks!!!
Offline fnunezsa
« Reply #4 on: February 04, 2011, 07:16:44 PM »
Out of the box Hyperion based reports may be found on the Genesys Reporting Templates CD.
Kind regards,
Franklin.
tony
« Reply #5 on: February 04, 2011, 10:33:21 PM »
Thanks Franklin - I did mention that... :)
TT
[quote author=fnunezsa link=topic=6088.msg26795#msg26795 date=1296847004]
Kind regards,
Franklin.
