" /> Softphone Question - Genesys CTI User Forum
Author Topic: Softphone Question  (Read 2911 times)
Offline vivek
Softphone Question
« on: September 21, 2010, 05:29:33 PM »
Softphone was developed to handle phone and non-phone contact using VB6.0. Wondering can this softphone be used for version 7.5 or 8?
Thanks.
Offline imaki
Re: Softphone Question
« Reply #1 on: September 24, 2010, 11:43:48 AM »
I guess it is using TLib or activex. Then it should be able to handle voice contacts on version 7.5.. (I dont know about 8)
Non-voice contacts are most probably designed for ICS, which does not exist on 7.x onward, so most probably you are out of luck for those contacts..
