Ok - added that verbose = 2 - attempted to login again and here is the log results:
MSGCFG_CLIENTREGISTER
attr: SATRCFG_PROTOCOLEX value: "CfgProtocol 5.1.3.70"
attr: SATRCFG_PROTOCOL value: "CfgProtocol 5.1.3.54"
attr: SATRCFG_USERPASS value: "******"
attr: SATRCFG_USERNAME value: "Angela Marceau"
attr: SATRCFG_APPPASS value: ""
attr: SATRCFG_APPNAME value: "IRD"
attr: IATRCFG_APPTYPE value: 51 [InteractionRoutingDesigner]
attr: IATRCFG_REQUESTID value: 2
13:20:53.643 AUT_MAIN: Put request to queue. Request ID = 0
13:20:53.643 AUT_MAIN: Request in queue. Request ID = 0
13:20:53.675 AUT_DBG: Authentication request received. Request ID = 0
13:20:53.675 AUT_DBG: Error description file ldaperrors.txt is processed
13:20:53.675 AUT_DBG: Error code [81] set to be retried
13:20:53.675 AUT_DBG: Error code [85] set to be retried
13:20:53.675 AUT_DBG: Error code [91] set to be retried
13:20:53.675 AUT_DBG: Error code [-1] set to be retried
13:20:53.675 AUT_DBG: Error code [-11] set to be retried
13:20:53.675 AUT_DBG: Native authentication function returned 0, system code = 0
13:20:53.675 AUT_DBG: Request [0] is in progress, stage 0
13:20:53.675 AUT_DBG: Checking connection object for request [0], stage 0
13:20:53.675 AUT_DBG: Checking retry-timeout for request [0]
13:20:53.675 AUT_DBG: Retry-timeout check passed for request [0].
13:20:53.675 AUT_DBG: Trying to connect for request [0].
13:20:53.675 AUT_DBG: Connecting to ldap server: citnetldp.citnet.cit.com:389...
13:20:53.675 ldap_create
13:20:53.675 ldap_url_parse_ext(ldap://citnetldp.citnet.cit.com:389)
13:20:53.675 ldap_simple_bind_s
13:20:53.675 ldap_sasl_bind_s
13:20:53.675 ldap_send_initial_request
13:20:53.675 ldap_new_connection
13:20:53.675 ldap_int_open_connection
13:20:53.675 ldap_connect_to_host: TCP citnetldp.citnet.cit.com:389
13:20:53.722 ldap_new_socket: 832
13:20:53.722 ldap_prepare_socket: 832
13:20:53.722 ldap_connect_to_host: Trying 159.3.96.46:389
13:20:53.722 ldap_connect_timeout: fd: 832 tm: -1 async: 0
13:20:53.722 ldap_ndelay_on: 832
13:20:53.722 ldap_ndelay_off: 832
13:20:53.722 ldap_open_defconn: successful
13:20:53.722 ldap_send_server_request
13:20:53.722 ldap_result msgid 1
13:20:53.722 ldap_chkResponseList for msgid=1, all=1
13:20:53.722 ldap_int_select
13:20:53.722 read1msg: msgid 1, all 1
13:20:53.722 ldap_read: message type bind msgid 1, original id 1
13:20:53.722 ldap_chase_referrals
13:20:53.722 read1msg: V2 referral chased, mark request completed, id = 1
13:20:53.722 new result: res_errno: 49, res_error: <80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 52e, vece>, res_matched: <>
13:20:53.722 read1msg: 0 new referrals
13:20:53.722 read1msg: mark request completed, id = 1
13:20:53.722 request 1 done
13:20:53.722 res_errno: 49, res_error: <80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 52e, vece>, res_matched: <>
13:20:53.722 ldap_free_request (origid 1, msgid 1)
13:20:53.722 ldap_free_connection
13:20:53.722 ldap_free_connection: refcnt 1
13:20:53.722 ldap_parse_result
13:20:53.722 ldap_msgfree
13:20:53.722 ldap_err2string
13:20:53.722 AUT_DBG: Error 49 Invalid credentials binding App user SRVgenesys
13:20:53.722 AUT_DBG: Server error message is: '80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 52e, vece'
13:20:53.722 ldap_unbind
13:20:53.722 ldap_send_unbind
13:20:53.722 ldap_free_connection: actually freed
13:20:53.722 AUT_DBG: Reset request [0], stage: 0, error code: 49
13:20:53.722 AUT_DBG: LDAP error 49 - Invalid credentials
13:20:53.722 AUT_DBG: Request cannot be retried[0], stage: 0, error code: 49
13:20:53.768 Std 22122 Client 804 failed to get authorization. Name [IRD], type [InteractionRoutingDesigner], user [Angela Marceau], address [159.3.108.107:3087]. Reason : Password is incorrect
13:20:53.768 Std 23500 Configuration Server Error : Error [CFGLoginIncorrect], object [], property [Unknown] Description Password is incorrect
13:20:53.768 Trc 04542 Message MSGCFG_ERROR sent to 804 ( '')
