Author Topic: CPD Detect voice Error  (Read 2402 times)
Offline ovident
« on: June 18, 2010, 04:29:32 AM »
Hi, all
I have the problem about CPD that
when CPD calling to Customer (have or no have calling melody), the system detect this case that "Answering Machine" (not happen every times)
please kindly suggest what will be the issue.
« Last Edit: June 20, 2010, 05:02:26 AM by ovident »
Offline Pranpong.S
Re: CPD Detect voice Error
« Reply #1 on: June 29, 2010, 05:54:52 PM »
What kind of Dialogic using for Dialer. Because you have to tunning some parameter of dialogic for more correct the detection. If u using the JCT with ISDN protocol. it very easy i can help you.
Pranpong
Offline johnphan
« Reply #2 on: September 25, 2021, 11:46:53 AM »
The first thing  you need to enable CPD debug, and collect the wav file, listen it carefully. Then copy to cpa-carieer message of MCP/CPD
Then, enable CPD dectection. The MCP/CPD/CPA will compare the annoucement and this voice. Thats all.
John
