" /> Create multiple Objects or bulk load in CME using PSDK - Genesys CTI User Forum
Author Topic: Create multiple Objects or bulk load in CME using PSDK  (Read 3905 times)
Offline Akash
« on: June 15, 2010, 12:52:31 PM »
Hi All,
I'm trying out creation / modification  of objects in CME using configuration platform SDK in Java.
Is there any method to create/ modify multiple Objects in CME using PSDK , Please provide some sample or guide in the right direction.
Offline ecki
Re: Create multiple Objects or bulk load in CME using PSDK
« Reply #1 on: June 15, 2010, 01:27:03 PM »
Did you know that there is Genesys Configuration Import Wizard which you can use to import a big load of configuration data  (DN,Skills,Agents...) from several switch export formats, xml, excel spreadsheet etc. You do not have to use SDK for that unless you are building some permanent synchronization application.
e.
« Last Edit: June 16, 2010, 12:36:15 AM by ecki »
