Author Topic: Complex Statistic  (Read 3486 times)
Massimo
Complex Statistic
we have to create a CCPulse template that shows the current number of Agents in Ready, InboundTalk , ... status. Also in this template, we have to show the current number of <agents in AfterCallWork + agents in NotReady status with NotReadyReason="A" + agents in NotReady status with NotReadyReason="B">.
If I create a statistic with MainMask=AfterCallWork,NotReadyForNextCall , then I cannot use the filters because there is no NotReadyReason in case the agent is in ACW.
I could create 1 statistic to measure the number of agents in ACW and a statistic that measure the number of not eady agents with NotReadyReason "A" or "B", but how can I then add them a show them as a single value in CCPulse?
Is there a way to sum 2 different statistics in StatServer or in CCPulse?
