Author Topic: How SIP server can modify the call id?  (Read 3303 times)
Offline kapusta1152
« on: January 11, 2010, 04:26:40 PM »
Does  Genesys SIP server  7.6 modify the call id?
Please describe some scenarios if possible.
Re: How SIP server can modify the call id?
« Reply #1 on: January 11, 2010, 10:54:09 PM »
What do you mean?
Offline Timur Karimov
« Reply #2 on: January 12, 2010, 06:26:00 AM »
[quote author=kapusta1152 link=topic=5062.msg22460#msg22460 date=1263227200]
Hi there!
I know only one posible scenarios for this - network transfer call from one site to another in multi-site solution.
But if it bring the error in your envrovment - you can try different type the ISCC routing type to avoide this situation. Also from statistic side you can configure your stat and icon server to  you original call id to call tracesing instead the changed one.
Hope it's helpfull for you
WBR Thaler
Offline kapusta1152
« Reply #3 on: January 12, 2010, 10:40:17 PM »
Your answer is excellent!  This is exactly what taking place with our SIP 7.6  environment after network transfer.
