Author Topic: Hiding all agents in CCPulse  (Read 2308 times)
Offline Scottyjohn
« on: January 04, 2010, 11:42:48 AM »
Hi all,
I am looking at hiding all the agents whether they are logged in or logged out, and then only show them when a criteria is met.  I can do the hide logged in and hide logged out, and the show on criteria is fine also, but is there a way to hide the agents in all other states without having to daisy chain a list of possible states?
Any help appreciated
tony
Re: Hiding all agents in CCPulse
« Reply #1 on: January 04, 2010, 01:50:09 PM »
Try using the "is not equal to" operator in your Threshold... Something like [b]!=[/b]
HTH?
Tony
