Author Topic: Import CFG DB  (Read 3073 times)
JC
Import CFG DB
« on: December 29, 2009, 04:30:23 PM »
Hi All,
I've exported my Config DB using the Export Wizard into a large sql file. I want to import this into a test environment but I'll be damned if I can't find an easy way to do it! I'm contemplating manually editing the file so that it will run as an Oracle query (source and destination are Ora 10g). What obvious tool have I missed?
JC
Offline Sylvainsjc
Re: Import CFG DB
« Reply #1 on: December 30, 2009, 09:32:28 AM »
I usually do this with oracle tools (exp and imp)
Marked as best answer by on Today at 11:30:30 AM
Offline borkokrz
Re: Import CFG DB
« Reply #2 on: January 04, 2010, 09:55:46 AM »
  • Undo Best Answer
  • Genesys tool called Configuration Conversion Wizard will do the job with moving CfgDB data between different database engines.
