Author Topic: GVP 7.6 EMPS SPS Core dumpage...  (Read 4444 times)
Offline blakemas
« on: December 17, 2009, 08:23:04 PM »
sigh... I have looked through the solution search at Genesys and haven't found any answers.  Just wanted a quick canvas if anyone has come across SPS core dumping when trying to add/change customers.  The implementation has no problem changing/adding provisioning on any server objects or server groups/ DID's etc.
The implementation is on Solaris 10, SunOne 5.2 LDAP, Oracle 10g.
I have checked permissions on the LDAP,  These seem to check out.
GVP.ini
[code]
[SPS]
SCACurrentObject=SPS
SCAGenerated=1
SCAParentObject=cn=ctccv020,ou=Servers,o=gvp76
adjunctdbactive=0
appxmlgenerationinlegacyfolders=1
cachepurgeflag=1
cachepurgetemplate=http://$cacheusername$:$cachepassword$@$cache$:8081/CE/Delete/http/$dispenser$/$dispenserftppath$/$xmlfile$
cfgappname=default
cfgapptype=CFGSCE
cfgchangedtemplate=http://$server$:$httpport$/webnotify.php?notifyProcess=WatchDog&Action=CFG_CHANGED
cfgpassword=password
cfgport=2020
cfgserver=localhost
cfgusername=default
clsid={fa0bacb4-9d13-4fef-8913-b8e763420fac}
dbbridgeinterval=600
dbinitialcatalog=Not Needed for Oracle
dbpassword=emps
dbserver=ctccs002.U1gvp
dbtype=Oracle
dbusername=emps
defaulttoctisimulator=0
deletepurgeinterval=45
dlls=
enforceuniquetfn=1
exe=SPS
gvptenancy=1
httpport=9810
httptimeout=2000
ldapbindpwd=<password removed>
ldapport=389
ldaprootdit=o=gvp76
ldapserver=ctccv020
ldapuser=cn=Directory Manager
loglevels=*:0x07
logmaxsize=1048576
logulids=
operatingmode=Standalone
scheduledtasksactive=0
scheduledtasksinterval=180
schemafile=../config/schema.xml
serveriplookup=0
serverversion=7.6.41
soapport=18025
spsdatasourcetype=2
spsoptionsset=1
startupsequence=11
templatelink=cn=SPS,cn=$version$,cn=EMPS
vwpsmode=1
vwpssystemaccountpassword=password
xmldidfolder=/opt/gvp/cn/web/did_url_mappings
xmldispenserfolder=did_url_mappings
xmldispenserhost=http://$dispenser$
xmldispenserhttptemplate=http://$dispenser$/did_url_mappings/$appxmlversion$/$appxmlname$
[/code]
SPS.log
[code]
[2009/12/17 19:39:45.093] 3    <<< DebugLog Start, pid=7433, ModuleVersions=/opt/gvp/cn/bin/libLogger.so:  7.6.410.02;/opt/gvp/c
n/bin/libicuuc.so.28:  ;/opt/gvp/cn/bin/libldap50.so:  ;/opt/gvp/cn/bin/libxerces-c.so.27:  ;/opt/gvp/cn/bin/libxerces-depdom.so
.27:  ;/opt/gvp/cn/bin/libDPL.so:  7.6.410.12;/opt/gvp/cn/bin/libstlport.so.1:  ;/opt/gvp/cn/bin/libicudata.so.28:  ;, Hostname=
ctccv020, HostIP=10.69.144.20, maxsize=1048576 >>>^M
[2009/12/17 19:39:45.092] 3    <<< DebugLog Start, pid=7433, ModuleVersions=/opt/gvp/cn/bin/libLogger.so:  7.6.410.02;/opt/gvp/c
[2009/12/17 19:39:45.316] 3    <<< Adding log flags >>> *:0x07
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:396 C=34:L=4:U=1026 ActionLoader initialization for namespace =
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem dbbridge in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem diagnosticsmanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem groupsmanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem optionsmanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem ping in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem rcamanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem servermanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem tasksmanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:430 C=34:L=4:U=1026 ActionItem usermanager in DLL_unknown
[2009/12/17 19:39:45.336] 3    ActionLoader.cpp:443 C=34:L=4:U=1026 ParserItem querystringparser in DLL_unknown
[2009/12/17 19:39:45.337] 3    GenericProcessControl.cpp:574 C=34:L=4:U=1026 GenericProcessControl::initializeDone - process now
ready to run
[2009/12/17 19:39:45.405] 3    SPSConfig.cpp:214 C=76:L=4:U=0 init >> Parameters read.
[2009/12/17 19:39:45.421] 3    DPLManager.cpp:210 C=78:L=1:U=0 SUNONE DS initialization succeeded.
[2009/12/17 19:39:45.422] 3    DPLManager.cpp:210 C=78:L=1:U=0 SUNONE DS initialization succeeded.
[2009/12/17 19:39:45.423] 3    DPLManager.cpp:210 C=78:L=1:U=0 SUNONE DS initialization succeeded.
[2009/12/17 19:39:45.424] 3    DPLManager.cpp:210 C=78:L=1:U=0 SUNONE DS initialization succeeded.
[2009/12/17 19:39:45.441] 3    SPSOptionsManager.cpp:112 C=76:L=4:U=0 Feature(featureMultiTenancy) , value(1)
[2009/12/17 19:39:38.250] 11  RCAManagerAction.cpp:106 C=76:L=4:U=0 execute >> Entered.
[2009/12/17 19:39:38.251] 11  RCAManagerAction.cpp:161 C=76:L=4:U=0 execute >> initialize base object...
[2009/12/17 19:39:38.251] 11  cnCustomer.cpp:56 C=76:L=4:U=0 formSelfInfo >> Entered.
[2009/12/17 19:39:38.252] 11  SPSOptionsManager.cpp:112 C=76:L=4:U=0 Feature(featureMultiTenancy) , value(1)
[2009/12/17 19:39:38.252] 11  RCAManagerAction.cpp:175 C=76:L=4:U=0 execute >> Caling handleAction()...
[2009/12/17 19:39:38.252] 11  SPSSchemaManager.cpp:805 C=76:L=4:U=0 Found a matching record set
[2009/12/17 19:39:38.252] 11  SPSBaseObject.cpp:1322 C=76:L=4:U=0 Location is(cn=Admin,cn=GVPOwner,ou=resellers,o=gvp76)
[2009/12/17 19:39:38.253] 11  DPLLDAPImpl.cpp:1429 C=78:L=1:U=0 isNodePresent >> Search failed for DN [cn=Admin,cn=GVPOwner,ou=resellers,o=gvp76] with errornumber [32], desc [No such object]
[2009/12/17 19:39:38.253] 11  SPSSchemaManager.cpp:805 C=76:L=4:U=0 Found a matching record set
[2009/12/17 19:39:38.254] 11  DPLLDAPImpl.cpp:2633 C=78:L=1:U=0 Fetch >> Failed to search DN [cn=Admin,cn=GVPOwner,ou=resellers,o=gvp76], Errnum [32], ErrDesc [No such object].
[2009/12/17 19:39:38.254] 11  SignalCatch.h:61 C=1:L=1:U=0 Processing signal 11
[2009/12/17 19:39:38.571] 11  SignalCatch.h:82 C=1:L=1:U=0 A copy of the stack traces is stored in /var/tmp/stack.SPS.7393.11.5F5D.tmp
[2009/12/17 19:39:38.571] 11  GenericProcessControl.cpp:338 C=34:L=4:U=0 setShutdownType called, type=3
[2009/12/17 19:39:38.571] 5    SoapServer.cpp:185 C=1:L=2:U=0 SPS soapShutdownSignalHandler: thread [5]: rcvd signal = 40. Starting shutdown
[2009/12/17 19:39:38.571] 5    SoapServer.cpp:194 C=1:L=2:U=0 SPS soapShutdownSignalHandler: thread [5]: Signaling shutdown
[2009/12/17 19:39:38.571] 4    GenericProcessControl.cpp:281 C=34:L=4:U=0 doShutdown entered
[2009/12/17 19:39:38.571] 4    GenericProcessControl.cpp:294 C=34:L=4:U=0 Waiting for Request Queue to empty out...
[2009/12/17 19:39:38.571] 4    GenericProcessControl.cpp:328 C=34:L=4:U=0 Shutting down...
[2009/12/17 19:39:38.572] 2    SoapServer.cpp:334 C=1:L=2:U=0 SPS soapMainThread: Shutdown event signalled. Exiting
[2009/12/17 19:39:39.080] 2    ThreadPoolEx.cpp:868 C=1:L=4:U=4 Threadpool [SoapServer.cpp:817] : still has 1 threads and 2 Q items
[2009/12/17 19:39:39.590] 2    ThreadPoolEx.cpp:868 C=1:L=4:U=4 Threadpool [SoapServer.cpp:817] : still has 1 threads and 2 Q items
[2009/12/17 19:39:40.100] 2    ThreadPoolEx.cpp:868 C=1:L=4:U=4 Threadpool [SoapServer.cpp:817] : still has 1 threads and 2 Q items
[/code]
If no ones seen it before no drama's ill log it with tech support...
Re: GVP 7.6 EMPS SPS Core dumpage...
« Reply #1 on: December 18, 2009, 12:48:11 PM »
SPS crashed as it received signal 11 (SIGSEGV - Segmentation fault -- an address reference boundary error). I would recommend you to raise ticket with Genesys TechSupport as they are able to analyse core dump and find out what is wrong.
Offline blakemas
« Reply #2 on: December 20, 2009, 06:30:04 PM »
Cheers René
