Author Topic: GVP Obn Problem or OCS Problem...  (Read 3386 times)
Offline GenesysNewbie
« on: December 17, 2009, 03:05:55 AM »
Hi guyz, i have this proactive dialing ok, BUt today i realized that when the register has user-defined columns and them have a letter Ñ the call is not dialed, and teh call_result is updated in this way: OK.
So i do not know, where is teh problem, OCS? OBN? where...
some tip?
Re: GVP Obn Problem or OCS Problem...
« Reply #1 on: December 17, 2009, 09:18:23 AM »
It's hard to say... I would recommend you to check logs and find out what has happened with the call. Post the logs here (debug level pls) if you need help.
« Reply #2 on: December 17, 2009, 07:30:57 PM »
Hi Rene, by looking logs seams that the URL is "malformed" when a world that has an "Ñ" is attached in teh user Data.
See the logs please.
« Reply #3 on: December 17, 2009, 07:42:43 PM »
Instead of Ñ you need to add the HTML representation for it, like for á é í ó or ú...or ü
« Reply #4 on: December 17, 2009, 07:58:47 PM »
Hi Cav, friend, very sorry but ur recommendation it is not clear
Let me provide u further information.
I have a calling List. 4 Example this..
ID/Phone/Name.  ok? so the values can be like this
01/123456789/Javier
02/345678912/Jorge
The problem apears when i have thsi register
02/345678912/Ñ or í,á,é, etc.  <=only  in thsi case teh call_result appears like OK.
HAve u deal with sth similar?
« Reply #5 on: December 18, 2009, 12:57:26 PM »
It seems that OCS/OBN is not able to convert non-ASCII characters correctly so XML file sent to CFA becomes corrupted. I think you have just one option to make it working - remove non-ASCII characters from calling list.
Of course, you can try to raise ticket with Genesys but I would expect the answer will be "international characters are not supported".
« Reply #6 on: December 18, 2009, 06:38:23 PM »
We decided to manage teh issue by the DB...
However i opened a SR, if i get a positive response, or solution i will posting it, if not ur prediction becomes true.
Thank u  very much all of u guyz
