Author Topic: How to setup backup Iserver, tserver for GVP  (Read 3958 times)
Offline uho001
« on: December 16, 2009, 10:02:14 PM »
Hi All:
  i am looking for some instructions of how to setup iserver tserver in warm standby mode for GVP. Any help would be appreciated.
Offline CTIgem
Re: How to setup backup Iserver, tserver for GVP
« Reply #1 on: December 17, 2009, 01:07:44 PM »
TserverIVR didn't work for me properly in warm standby mode.
I think this is because they expect us to use load balance.
Offline uho001
« Reply #2 on: December 17, 2009, 06:49:53 PM »
What problem you got with warm standby?, i have setup two ivr servers and tservers in primary/backup mode, but i cannot switchover one tserver to another, sci shows service unavailabe forever.
« Last Edit: December 17, 2009, 06:56:08 PM by uho001 »
Offline blakemas
« Reply #3 on: December 17, 2009, 08:00:35 PM »
[quote]What problem you got with warm standby?, i have setup two ivr servers and tservers in primary/backup mode, but i cannot switchover one tserver to another, sci shows service unavailable forever.[/quote]
That would be right as the second IVR T-Server is not connected to the GLI link.  We have it set to Load balance for GVP.  On another integration with a First Contact IVR through the IVR SDK the results are similar in that the secondary IVR Server is always unavailable until the primary fails.  So far our testing shows that you cannot use the SCI fail over function.
We haven't found a way to have one GLI link dually connected to an IVR T-Server.  If anyone has any further information that would be appreciated.
Offline CTIgem
« Reply #4 on: December 18, 2009, 01:52:07 PM »
As I recall, in their doc, it only supports warm standby thru load balance.
Yes, you would see service is unavail and switch over function is disabled.
Juan Perez
« Reply #5 on: December 20, 2009, 06:36:06 AM »
You can configure Alarms/Actions to start and stop the main/secondary.  This will work as backup service.
