Author Topic: IRD - Scheduler  (Read 4491 times)
Offline kennyguk
IRD - Scheduler
« on: December 11, 2009, 10:16:58 AM »
I am trying to load schedules so that IRD can route calls correctly over the Christmas period without any human intervention.  ;)
I am doing some tests and when the time passes for my schedule to load the Routing Point does not display my new strategy. I am looking in the URS Log and I keep seeing this message next to the attempted event of the schedule loading, "CONT: config server error 9 - object CfgDN(2), property DBID(34) : Permission error. Your access privileges are insufficient for performing the requested transaction."
This doesn't make sense as the user I am loading the strategies with is within Ranks IRD - Administrator, Strategy Builder - Administrator and Strategy Scheduler - Administrator.
Thanks in advance for any help
Kenny
Offline borkokrz
Re: IRD - Scheduler
« Reply #1 on: December 11, 2009, 11:16:01 AM »
From which account URServer is running (check Security tab in CME)  ? Is it SYSTEM account or any other, custom account ? If custom one - check permissions to RoutingPoint DN for this account - it has to be at least RHX.
Are you using geographically distributed environment with CSProxy and URServer is running from CSProxy ? If yes - you won't be able to use scheduler, due to Read-Only mode of CSProxy.
Offline kennyguk
Re: IRD - Scheduler
« Reply #2 on: December 11, 2009, 01:11:43 PM »
Im running IRD from my laptop which connects to the server with URS on it,
I checked the Security tab in CME for that Routing point and Admins and Super Admins have "Full Control" set
Offline borkokrz
Re: IRD - Scheduler
« Reply #3 on: December 11, 2009, 01:28:57 PM »
Check the Security tab of URServer, section "Log on as". Account specified there is used by URServer during scheduler execution. URServer simply changes annex tab of RoutingPoint DN. Your account used in IRD doesn't matter in this case.
Offline kennyguk
Re: IRD - Scheduler
« Reply #4 on: December 11, 2009, 01:34:04 PM »
on UR Server the Security tab has "Log on As - System Account" set at the moment.
Offline borkokrz
Re: IRD - Scheduler
« Reply #5 on: December 11, 2009, 01:43:23 PM »
Does SYSTEM account have security access to RoutingPoint DN ?
Offline kennyguk
Re: IRD - Scheduler
« Reply #6 on: December 11, 2009, 01:49:45 PM »
on the Routing Point SYSTEM only had RX access, I have changed that to Full Control and this appears to have fixed the issue.
Thanks for your help Borkokrz  ;D
Offline borkokrz
Re: IRD - Scheduler
« Reply #7 on: December 11, 2009, 02:08:17 PM »
RHX is enough, but Full Control will also work ;-) You must correct this on all RP DN's on which you want to change strategy by IRD Scheduler.
