Author Topic: SCI alarmming  (Read 3029 times)
Offline makkerc
SCI alarmming
« on: December 10, 2009, 01:52:07 PM »
Is there anyway of setting up an alarm for Disk Space and avaiability through SCI on Unix boxes?
Cheers...
Offline borkokrz
Re: SCI alarmming
« Reply #1 on: December 10, 2009, 02:26:19 PM »
AFAIK no, because LCA can only monitor CPU and Memory Usage.
Offline blakemas
Re: SCI alarmming
« Reply #2 on: December 17, 2009, 08:47:26 PM »
Not natively is what I think the chap above is trying to say.  You could write a script on the host to monitor the utilization on the concerned partitions then return the alarm using the logmsg executable that is distributed with message manager.
guest
Re: SCI alarmming
« Reply #3 on: January 06, 2010, 02:31:22 PM »
Yes ,it is possible....had AIX boxes.......created a alarm that would execute a shell script located in the SCS installation folder. This script can be used to do all sorts of custom action required as possible .
guest
Re: SCI alarmming
« Reply #4 on: January 06, 2010, 03:01:32 PM »
It's possible using custom alarm with SNMP traps.
Cheers
